I am capturing some home movies from my analog camcorder through an ATI AIW 9800. I am using virtualdub_sync. I have disabled my network connection and any services not needed. I get a single frame drop every one minute and forty seconds. This occurs regularly from the start of the capture. My system is a 3.2 Ghz P4 with 2 GB RAM. CPU usage never gets above 20%. I am using Huffyuv for compression. Other random frame drops are quite rare. I know I won't see these in the finished DVD but I am trying to find the source. I don't believe it is the computer or other software on the system as it is exactly every 1:40 from the start of the capture. I have virtualdub_sync set to dynamically sample audio and not drop frames if out of sync.
Any ideas?
Thanks,
Chris
Hi cmassa,
Welcome to the site and the forums
You posted in the "Capturing" forum - go back to it's page and there are a couple of "Stickys" that might well be of interest...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I have looked through those and haven't seen things relating to very regular frame drops. I don't remember it happening on previous captures but maybe I didn't notice the regularity. I'm guessing it is virtualdub_sync dropping a frame to remain in sync with the audio but I thought this version was supposed to change the audio and not drop frames to compensate.
Chris -
Antything acessing the drive such as Windows indexing service? Might want to open task manager (ctrl-alt-delete) while captureing and see if there's any CPU spikes from other processes while your capturing.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 06:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 23:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 14:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
