Hello all,
I have a few qucik questions...
How would I go about putting VCDS onto a DVD. Is there a way to do this without any conversion? If not, what software (freeware?) is avalible to convert VCD to DVD format.
Thanks for all your help,
ccg.
Check the how to author guides on the left,it tells you how to author vcd to dvd without re-encoding.
Total freeware, eh? Okay, I'm thinking dvdauthor and DVDauthorGUI, they'll take mpeg1 streams okay. You have to use elementary streams, unless later versions can take an MPEG1 directly. (?) Sooo, demux in TMPGEnc or bbmpeg. Run the audio through ffmpegGUI to make it compliant, convert to ac3 while you're at it. Then drop your video and your (fixed) audio separately into DVDauthorGUI. Enter chapter points as desired. Want more than one on your DVD? Of course you do.
Just add another title.
Good luck. That's just off the top of my head. There are guides over there <-- for this, but whether there's an all freeware version, I dunno.
Pull! Bang! Darn! -
Why convert it to ac3? Can't you just leave it as mp2?Originally Posted by fritzi93
yes you can leave it alone. its just a slight chance that a few dvd players might not be able to play mp2 but i haven't heard of any....
How Big A Boy Are Ya? -
Read this sticky:
https://www.videohelp.com/forum/viewtopic.php?t=129786
Search is your friend
If in doubt, Google it.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 05:14 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15
