UPdate..................
https://www.videohelp.com/forum/viewtopic.php?p=1291964#1291964
Results 31 to 56 of 56
I think I understand now. This refers to the 'Render As' dialog, right?Originally Posted by sync
The 4CC changer I have only has these options for Description code - XVID, DIVX, DIV3, DIV4, MP43, MP42Originally Posted by BJ_M
use DIVX
I got it to work by upgrading to Divx 6 and then removing the XVID codec.
But Vegas doesn't work well with Divx. It's quite sluggish. I think I'll be converting the Divx files to MJPEG before editing. -
if you want speed == use DV instead
if you want quality -- dont covert anything , but use a proxy file , then swap for final rendering ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I haven't heard of proxy files before. I googled it and the name GearShift came up a lot. Is that what you recommend?
Hey, I also have come across this recently. Sorry to bring up an old thread but didn't want to create a whole new topic. Xvid worked fine in Vegas 6.0, then un-installed Xvid then the newer but after I updated my Xvid it stopped working. Get the no attributes error. Tried the CC Changer that came with it and didn't work. Changed them as mentioned in this post. That did nothing. Downloaded the latest Divx bundle and still nothing. Any help would be appreciated.
Tried that and nothing. Do you think it has something to do with a previous removal of the file xvid.dll. It was causing problems with my explorer and I had got rid of it but then just tried putting a different copy that I got but still nothing.
this issue has been been beaten to death in the vegas forums -- and no real perm. solution that works for everyone has been found ..
best bet is to frame serve from an earlier version of vegas to newer version of vegas .
as with other pro NLE, support for xvid (or divx to a lessor degree) is not a top priority .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
btw, just wanted to point out...i know this topic was started a while ago, but the whole divx fast motion vs slow motion.....at that point, you had EXTREMELY old divx codecs installed (divx 3!) so that's likely part of the reason you couldnt properly import the files....
Hey, I have finally fixed this problem, for the most part. I had it so it read every AVI video as 3IVX and a lot of my vids wiould play choppy and picture would get messed. But after some fooling around got it to read everything as Divx 5 which is defenitely good enough for me. Now this isn't totally related but now I notice, even before the switch. It won't read a lot of the audio with these clips. The only ones it picks up are the rescent clips I have captured which are uncompressed audio. Anything I can do to make it so it reads all other audio formats again. Sorry for the bother, any help is appreciated.
I'm not sure if this can be used as a general fix for everyone, but here is how I finally got all my divx and xvid files (video and audio stream) to import correctly in Vegas:
- Installed the latest update of Vegas (v.6.0.d)
- Installed the latest divx codec (v.6.1)
- Installed the latest version of AutoGK (v.2.27) which contains the xvid codec
Important:
Before you can successfully import any divx or xvid file in Vegas, you HAVE TO change the fourcc header to "DIVX" (all caps)!!! Most of the divx files I had showed DX50, with that Vegas DID NOT recognize the audio stream. To change the fourcc header I use a small application called aviC.exe which can be downloaded for free here http://www.divx-digest.com/software/avifourcc.html
Hope this helped.
yes -- kinda what i suggested in the first post
but even then - some still have problems"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I have a solution that works for me, i just want to know if that works with EVERY type of divx/xvid.
With satsuki codec pack, even if video was correctly played on Media player Classic, i couldn't import them into vegas.
but "taadaaa !!" here's come a special xvid codec ! it doesn't interfere with ffdshow or other when i just play them, but now i can import them ! in fact, i have this codec for 2 years, but i didn't know that the Vegas community had so many pb with xvid !!!
http://<a class="contentlink" href="http://perso.wanadoo.fr/kame.sennin/XviD4Vegas.rar...4Vegas.rar</a>
please let me know if that works !
edit: i tried some OOoold samples in divx3, did not work. but i assure you that this codec solves a LOT of pbs !! -
interisting -- ill look at it later .... to bad it is an old build of xvid
not a solution at all since it didn't work.Originally Posted by iasho
It seems IT IS a solution after all because at least in my case it's working perfectly!
I've been dealing with this problem nearly for a half of a century and now finally it's been solved. Beautiful! Just beautiful!
To iasho:
I can't even tell you enough how grateful I am.. Thanks VERY MUCH pal. Really. Thanks very much.
Having trouble importing avi's (divx/xvid) and mkv's into Vegas 10
By mr-scarface in forum Video ConversionReplies: 11Last Post: 17th Jan 2012, 11:11 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
What is the best DVD to Xvid (or DIVX) solution?
By Chrushev in forum Newbie / General discussionsReplies: 8Last Post: 19th Jan 2010, 17:11 -
Ok no Need for 4CC Changer for Vegas to Import Xvid/Divx fig
By canadateck in forum User guidesReplies: 11Last Post: 18th Sep 2008, 13:21 -
Best Solution for DivX/XviD on a TV (Apple TV or Media Center Extender)
By fletch407 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Jan 2008, 02:08
