Does anyone know what this could be.
When playing back some of my dvd's (noticed it on both the new Star Wars IV dvd and on some of the Indiana Jones dvd's) there is a Purple/Green line at the bottom of my tv screen. It starts out purple at the left of the screen and turns green at the right side. It is only about 1mm thick. This is when playing on my NAD T513 dvd player.
Is it my dvdplayer? it doesn't happen with all dvd's.
Maybe the SCART cable?
Or is it just something wrong with these particular dvd's?
I think the last is correct but I can't figure it out. Has anyone else with the PAL versions of these movies experienced the same?
Thanks for any help in advance.
I've seen a green line at the bottom of some videos when playing in MS Media player but it never showed up on the TV. Right at the very bottom and the reason I know it wasn't visible on the TV was because it was widescreen.
Remove green/purple "bloom" from video
By mikeveli20 in forum RestorationReplies: 4Last Post: 3rd Oct 2011, 16:08 -
Fairuse Wizard - Purple Line In Some Videos
By Simmons in forum DVD RippingReplies: 8Last Post: 26th Mar 2011, 11:18 -
green line at bottom of video window
By miniboss91 in forum Video ConversionReplies: 3Last Post: 11th Jan 2010, 21:51 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 22:29 -
Green/white noise line under video with mpeg2 format
By VistaXP in forum Capturing and VCRReplies: 2Last Post: 27th May 2007, 19:29
