  1. I sent the registration money last night, but have yet to receive a key from Major. Can anybody comment on the timing of the registration process? I need to convert a VCD to DVD for a trip in the next day or so. If the registration takes longer than that, I need to research other tools...
    Thanks.
    -Pete
  2. Why do you need to register for that? Just click the "try for free" button. The app is full function demoware
  3. Originally Posted by DeusExMachina
    The S/VCD -> DVD tool is for registered copies only. I tried opening a .DAT file directly, but it didn't work...
    -Pete
  4. So just do it manually. You can use the original video, since DVD supports VCD video size. Just convert the sound to DVD compliance. Then use whatever app you plan to use to format your video_TS file. iDVD or Toast will work fine, or you can use the author as DVD option in ffmpegx
  5. Peter, thank you for your support. Normally I answer mail within some hours, but this new year's weekend I didn't access my computer as frequently. You should have now received my reply.
  6. Thanks. The software is an amazing piece of work!
    -Pete
