Uh.. the message that started this thread says nothing about SlideShow Movie Maker, nor did it mention a need to create transitions between slides. It mentions slides and video clips on the same DVD, and it mentions a menu to select either the slideshow or the video: all of which requirements are catered for by standard DVD authoring features.Originally Posted by daamon
Yes, the author mentions Slideshow Movie Maker in a later message, but I believe he has been sent down that track by bad advice.
Results 31 to 48 of 48
Really? And where exactly in the thread does anyone specifically say "Use SlideShow Movie Maker"? If you read the responses of tin2tin, lordsmurf, nomads, Garibaldi, MOVIEGEEK and myself prior to the post you reference where SSMM is first mentioned by the original poster, the closest is when lordsmurf provides a link to a load of tools, and SSMM isn't even listed in there.Originally Posted by mpack
I would say that AeR0 has chosen SSMM himself and we've followed that with help and suggestions based on what was subsequently posted.
Get your facts right before criticising and not offering anything instead...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Well, since you ask: nobody specifically mentioned SSMM, but immediately before AeR0 mentioned SlideShow Movie Maker is your own message, which is a good case in point: because it says that his slideshow needs to be in "DVD compatible MPEG-2". In fact it doesn't need to be anything of the sort. DVDMaestro for example will accept JPEGs or BMPs for use as stills in a slideshow, and I doubt it is unique in that regard. Your message might well have got him thinking that he had to create the slideshow as an MPEG movie first, and then use that as an asset during authoring. That is certainly how I interpreted what you were saying.Originally Posted by daamon
In fact I offered two alternatives in my original response: I said that Audio DVD Creator could create slideshows with a soundtrack (but not handle the video clip requirement). Or, that any semi-pro DVD authoring app could do everything that he asked for.Originally Posted by daamon -
And what do you think DVDMaestro does with the JPEGs and BMPs? It encodes them to DVD compliant MPEG2 - just behind the scenes. Only MPEG2 can be authored to create VOBs etc.Originally Posted by mpack
So, your suggestion of Audio DVD Creator only half addressed his need - not much use really, is it?Originally Posted by mpack
And you then go on to make a sweeping general statement which encompasses all of the more precise previously suggested tools - repetition, useful...
Admit it - you fired from the hip and you're in an indefensible position. Let it go and let's got on with helping people...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I don't admit anything of the sort. I have provided an answer to the question at the root of this thread, and clarified it at your request. Now, whether AeR0 finds my contribution useful is up to him. Your opinion is somewhat less relevant.Originally Posted by daamon
Actually, shortly after posting that last message it struck me that your comments are still curiously ambiguous. Yes, each slide in the slideshow must ultimately be rendered in MPEG-2 form by the authoring app... but why would you feel the need to highlight just that part of the authoring apps responsibility and not others??
Then it struck me... you do realise that each slide is encoded as an MPEG-2 still don't you, and not as an MPEG-2 movie? In other words, you do understand that a slideshow is a series of stills and hold times, and is not a synthesized movie, right?
Perhaps the recent confusion has been due to my crediting you with more knowledge than you actually have. -
My opinion is relevant when you directly quote me and then erroneously accuse me of providing bad advice, and then you insist on arrogantly defending yourself when I merely asked you to get your facts right.Originally Posted by mpack
No...?Originally Posted by mpack
Really?
I felt it was more appropriate to answer the questions and not to introduce confusion by introducing alternatives - the "learning one step at a time" philosophy. Whereas you disagree - fine, we have different views. Let's agree to disagree.
Ah, not a bad attempt at getting close to a riposte. Good effort - B+.Originally Posted by mpack
I shall ask again - please leave it now. This is of no use to AeR0 (apart from, perhaps, mild amusement at your vain attempts at jibes). If you want to carry on this "off topic" crusade, start a thread in the Off Topic forum. Don't expect me to join in - I'd rather be helping people than being distracted.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I, for one, don't have $5K to spend on DVDMaestro, when Slide Show Movie Maker is free and can do the job I need it to do ...
I know which one I'd choose, but that's just me
If in doubt, Google it. -
Don't have $5k to spend? I'm sure you don't, and in any case Maestro is no longer sold, and besides which I'm sure its features are not unique (eg. no doubt DVD-Lab would do just as well). Unfortunately, Maestro is the DVD Authoring tool I'm familiar with, so I'm not in a position to recommend alternatives - which is why I did not do so...Originally Posted by jimmalenko
This IS constructive .. .grain of salt please
I seriously doubt that - otherwise DVD-lab would be sold for a similar price instead of $100 (or $200 for the Pro version), no ? ... and given that you know nothing about the alternatives (see below), methinks someone was talking out their assOriginally Posted by mpack
So why attack someone else for recommending alternatives (of which you know nothing about by your own admission) then ?Originally Posted by mpack
Please get your facts straight
*** Remember, it's better to let people think you are stupid, than opening your mouth and removing all doubt
Hi AeR0,
If you just need to throw down some slides and some video on a dvd(and the menus isn't all that important), I just want to mention, that I've added import/export of avi's to the DVD slideshow GUI now(6.jan). So avi's can be mixed with slides and music, rendered to mpeg2, muxed, authorised as a ready to burn dvd-.iso file. All in the same free proggy.
Have fun,
Tin2tin -
Nice one tin2tin!!! I'm sure that'll prove very useful to alot of people.
Carpe diem.
jimmalenko wrote:
Actually, DVD-Lab is closer to DVDMaestro than you think. But it is silly to recomend a $5,000 app to do something that simple. It's about as dumb as sugesting everyone use CCE SP($2000), when they can get as good or better quality from TMPGEnc or MainConcept for less than 10% of the cost.I seriously doubt that - otherwise DVD-lab would be sold for a similar price instead of $100 (or $200 for the Pro version), no ? ... and given that you know nothing about the alternatives (see below), methinks someone was talking out their assGot my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Sorry I don't, I was just blindly trying it hoping it would work!Originally Posted by Garibaldi
I tried a test with a Huffyuv compressed file and this "fix" didn't work, neither did using uncompressed.
I don't use xvid, or any Divx variants, so haven't tested them. Maybe it only works with DV encoded files!
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Christ - is everyone participating in this thread a moron, or is it just great method acting?Originally Posted by jimmalenko
Learn to read for gods sake! I did not recommend or attack any specific tool, I questioned the METHOD initially being promoted here of converting a slideshow into a synthesized movie: ie. a method of simulating a slideshow which is enormously wasteful of disk space (in order to get a 10 second pause with a synthesized movie you must provide 10 seconds of at least the minimum bit rate to avoid underflows - and as a side effect giving your slide minimum quality at the same time!) when DVD has a standard built-in slideshow feature which only requires one MPEG still per slide, occupies negligable disk space, gives maximum quality, leaves most of the disk space for a PCM soundtrack or whatever else you want, and can be accomplished with any worthwhile DVD Authoring app: meaning anything other than the "one button and its done" shit. One example not enough, or Maestro not the right example for you? Well fine! Take your pick of the decent authoring apps then you tell me which one you can't do it with! -
You need to entertain the possibility that the fault lies with you and the way you present yourself... Consider the scenario where AeR0 says he's decided to use SlideShow Movie Maker and starts asking questions from there about AVIs (as actually happened).Originally Posted by mpack
At this point, are at any time later, you could've stepped in with words like:
"The way you're doing it will get the results you desire, however...
...and then go on to provide examples that you know of, or stating "Take your pick [from any] of the decent authoring apps".Originally Posted by mpack
Doesn't that make you sound like a much more reasonable and helpful person rather than how you actually came across? As evidenced by the similar replies, from more than one person, to your posts.
I agree with what you say - just not the way you chose to express it. And I'm sure AeR0 would be grateful for the information and any help on how to go about it...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Diplomacy is not one of my skills. However, I apologise for losing my temper. And there was I thinking I had left flame wars behind me a decade ago...
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
Creating a slideshow with slides at specific points in the audio
By Kiwi999 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Apr 2012, 01:18 -
Creating AVCHD slideshow
By chrisnewton in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 10th Dec 2010, 12:04 -
Creating flash/mpg/etc slideshow with text from file
By RandallM in forum Newbie / General discussionsReplies: 0Last Post: 12th Nov 2010, 13:50 -
Creating a slideshow as a standalone .swf file
By marioval in forum Newbie / General discussionsReplies: 8Last Post: 2nd Sep 2009, 12:36
