ok question is how do i create a picture slideshow dvd and a short video
all on advd-r 4.7
and i would like to create a menu to select either the slideshow or the video
any help?
Results 1 to 30 of 48
Hi AeR0,
If you want to do it with freeware you can use DVD slideshow GUI to render your slideshow. You can see the tutorial in flash here: flash tutorial.
Then you can use GUI for DVDauthor to make your menu with buttons and import the mpg from DVDslideshowGUI and your video as mpg(if you video is avi - you can encode it to mpg with quenc. Gui for DVDauthor guide here: DVD menu guide
Or
You can use DVDauthor GUI to set up your menu and add the dvd slideshow gui m2v+mp2 and your video to the dvd.
And finally burn with cdburnerxp pro
Have fun,
Tin2tin -
Pick one:
https://www.videohelp.com/tools?s=28#28Want my help? Ask here! (not via PM!)
Hi AeR0,
However you get there, you'll need both your slideshow and video in DVD compliant MPEG2.
When authoring, each one will go into it's own track and then the menu will list both tracks so the viewer can pick one or the other, as you want.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
ok ive got the picture slideshow program im using slide show movie maker version 3.7
how do i add a video now ? and how do i make a menu so i can select either the slideshow or the movie? -
Slideshow Movie Make (I believe) outputs to AVI. You need to encode this AVI to DVD compliant MPEG2, then follow my words in the post above.
If you're not sure on encoding, there's loads of guides to the left.
A good-t-start-with authoring app is TMPGEnc DVD Author, as well as others already mentioned.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
right the one i got puts it to a .avi video file.
could i still use this one? -
No. See my previous post. A pretty good but affordable encoder is TMPGEnc Plus.
Carpe diem.
AVIDemux is a good free AVI to Mpeg2 Recorder!
Originally Posted by GaribaldiThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Why use the Xvid codec? It just introduces quality loss. You're better off using something like a DV or similar codec, unless space is an issue...
Only 2Gb!!!
That's terrible!
Is that OS independent (i.e. FAT32 and NTFS)? And there's no setting in SSMM? It's not a limitation of a trial or something like that is it?
DV isn't quite uncompressed, it's compressed but at something like 25Mbps. Any DV codec should be OK, but the Panasonic DV codec is good and free.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Only 2Gb!!! ieek.gif That's terrible!
Is that OS independent (i.e. FAT32 and NTFS)? And there's no setting in SSMM? It's not a limitation of a trial or something like that is it? -
Well, I never knew that - then again, I've never used it.
Still useful to know though...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Still useful to know though... -
Anything that's compatible with SSMM and outputs an AVi, that's also lossless or close to it.
I'm not familiar with these - so check them out:
huffyuv (?)
PICVideo MJPEG (?)There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
About Huffyuv, I looked on their site and this was part of the description:
Huffyuv is an open-source, freeware codec that offers excellent performance, but obviously, as all other lossless video codecs as well, requires helluvalot of free HDD space -
Yeah - That 2Gb limit really is "a limit". How constricting...?
Carpe diem.
Originally Posted by daamon
I had a 2.92GB file (video only) produced by SSMM using a DV codec for compression. I couldn't get it to open in anything, but then thought I'd try Virtualdub.
I checked the box "Ask for extended options after this dialog" in the Open Video File dialog box. Then I checked the "Re-derive keyframe flags" box. Vdub started reindexing the file, and then rebuilt the keyframes, and it seemed to work! I saved it out to a new file using "Direct stream copy", and I couldn't see any problems with the file - it played fine. It did take a while, maybe 30 mins to reindex and rekey.
I was able to add the file into my NLE to mix with some Video, and then output to MPEG2.
Not an ideal solution, but it did seem to work. Would be interested if it works for anyone else."Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
I may be missing something - the consensus here seems to be drifting towards creating the slideshow as an AVI clip - ie. repeating each slide (frame) for as long as necessary, muxing with a soundtrack and encoding with MPEG2?
If so...
Why use a technique that is so wasteful of time and DVD disk space when DVD has a built in feature for displaying still images with background music? See Audio DVD Creator for an example of specialized software which can do it. Any semi-pro DVD authoring app will also let you do it (with a bit more work), and will also let you mix stills and motion backgrounds on the same dvd (which I don't think the specialized apps will). -
Well this is one of the many instances that having a NLE makes things so much easer.
Not any help. I know.
deek -
This might be of use/interest.
I may be missing something - the consensus here seems to be drifting towards creating the slideshow as an AVI clip - ie. repeating each slide (frame) for as long as necessary, muxing with a soundtrack and encoding with MPEG2? -
Ignore the little interlude that went on - you've got an AVI from SlideShow Movie Maker. This needs to be encoded to DVD compliant MPEG2.
You should also have a DVD compliant MPEG2 for your video.
Each of these, when authoring, will go into it's own track. The menu will then be able to give the option of choosing one or the other, as you want.
EDIT: And I forgot to add what Garibaldi says below...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 03:18 -
Creating a slideshow with slides at specific points in the audio
By Kiwi999 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Apr 2012, 00:18 -
Creating AVCHD slideshow
By chrisnewton in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 10th Dec 2010, 11:04 -
Creating flash/mpg/etc slideshow with text from file
By RandallM in forum Newbie / General discussionsReplies: 0Last Post: 12th Nov 2010, 12:50 -
Creating a slideshow as a standalone .swf file
By marioval in forum Newbie / General discussionsReplies: 8Last Post: 2nd Sep 2009, 11:36
