Hi,
I am using Ulead DVD Workshop 2. I have a video with aspect ratio 4:3. I want to create a DVD that will be able to display the video in 16.9 on widescreen TV and 4:3 on standard TV.
I have following questions,
Q1. Can someone tell me what display output options should I choose in Ulead DVD Workshop 2?
Q2. Do I need to create two seperate DVD's - one with 4:3 and other with 16:9?
Thanks for your help.
Joe
Best hing to do is author it with the correct ratio and adjust it with the DVD player.
It has to be one or the other it can't be both but you can use a DVDWS to author both a 16:9 and a 4:3 version on the same disc.
Not sure how you would do it directly in WS2 but the way I would do it is encode two seperate videos in each aspect in my editor then drop on the timeline and select do not convert compliant files.
Aspect Ratio Question
By rede96 in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2011, 05:17 -
Aspect Ratio Question + Some
By Alexander4444 in forum Video ConversionReplies: 7Last Post: 9th May 2011, 03:17 -
By kelticvixen in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2009, 14:27 -
aspect ratio question
By brianhj in forum Video ConversionReplies: 6Last Post: 16th Aug 2008, 13:54 -
Aspect Ratio Question (Sorry!)
By rede in forum Newbie / General discussionsReplies: 12Last Post: 30th Dec 2007, 08:25
