I have a selection of home movies on a DVD ram disc that i would like to convert so i can place them on DVD-R to use in other players.
The contents of the DVD ram is a folder "DVD_RTV" with in this folder are files "VR_MANGR.BUP", "VR_MANGR.IFO" & "VR_MOVIE.VRO".
so i presume the tool needed if its out there is to convert these to video_ts.bup,video_ts.ifo and vob. I have looked at various convertors with no sucess, im either looking at this the wrong way and trying to do a direct conversion when i should be trying to convert to, say AVi then to DVD.
Any help would be appriciated.
Thanks.
There are alot of topics on this, did you search?
Just use tempgenc dvd author to import your files. -
And assuming you have a dvd-rom that will read dvd-ram,
You can also just copy and paste the .vro file to your HD and rename it to .mpg and import it to TMPGEnc DVD Author to edit and author it to your video_ts folder and or burn with it or whatever burning program you use.
I have transferred tons of LD's this way.
Also making custom motion backgrounds for the menus and adding them to
TMPGEnc DVD Author. -
Thanks every one for your info on doing this task, i thought i had looked every where on here, but no.
There is a guide for it but you have given me a couple of other options
Thanks again all
Matshita DVD Ram UJ851s not recognizing blanc dvd
By ezradallas in forum ComputerReplies: 7Last Post: 12th Mar 2010, 12:50 -
Converting DVD-VR (DVD-RAM) with Multiple Tracks
By alexs77 in forum DVD RippingReplies: 2Last Post: 26th Dec 2009, 04:27 -
HOW to DVD-RAM on PC so that it plays in my PANA DVD Player
By saxon22 in forum Authoring (DVD)Replies: 21Last Post: 18th May 2009, 08:34 -
dvd recorder with dvd-ram, no hdd, gemstar tv guide, atsc or ntsc tuner.
By 84transam in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Nov 2007, 20:55 -
DVD-RAM from Panasonic ASTC recorder to PC for DVD authoring?
By Philbiker in forum Capturing and VCRReplies: 2Last Post: 30th Oct 2007, 18:42
