Hi,
I have quite a few single song files that are Mpeg2 and I want to make them into DVD files(VOB.BUP.IFO),but when I load the into TMPGencDVDAuthor I get to the encode to DVD stage and it tells me that the Bitrate is to high in the video.
How do I make these files DVD compatable without loosing any audio quality and loosing only the minimum in video quality.
Thanks In Advance,
Ian
doesn't TDA give you an option to "ignore"? I have chosen that option before in that circumstance without affecting the playability of the resultant dvdOriginally Posted by prbatman
Hi,
It does,but I wondered if there was any way to be sure it would be compatable.
I'll try it that way seeing as it works for you,and hopefully they should work OK.
Thanks,
Ian -
Unfortunately it creates a DVD file but when trying to play it,it just stutters and goes blocky.
Any Ideas! -
First make sure that the stuttering is not caused by cheap media. If you are using them then try something better.
Unfortunately, the only way to change the bitrate is to re-encode."Art is making something out of nothing and selling it." - Frank Zappa -
I've tried using DVD-Lab Pro by Demuplexing the Audio/Video.Leaving the Audio and lowereing the video bitrate.
This seems to be the solution,and very little(If any noticeable quality) is lost.
Is this the best option?
Converting .VOB files to MPEG4 with Streamclip and MPEG2 Playback Component
By MLK3329 in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 14:51 -
Converting or Muxing audio files (mp3 etc.) into MPEG2 TS without any video
By kary.sharma in forum AudioReplies: 1Last Post: 5th Dec 2008, 10:43 -
By kary.sharma in forum Video ConversionReplies: 1Last Post: 5th Dec 2008, 09:07 -
Best App for Converting MPEG2 files to WMV/WMA 5.1
By JBredensteiner in forum Video ConversionReplies: 13Last Post: 7th Oct 2007, 15:58 -
Need advice on converting MOD (mpeg2) files to usable format for iMovie
By InsanelyOne in forum MacReplies: 3Last Post: 9th Sep 2007, 16:23
