I have just recently upgraded my machine ..and reinstalled XP.
I am trying to reinstall some filters and codecs ...but having issues
In particular I am trying to install an AC3 filter for conversion work.
I right click on the .inf file and select install ...then XP sticks
its ugly butt in!!
It says it cant let me do this cause it doesnt follow the Microsft approved
driver ..etc program.
Anyone had this issue?? and anyone have a solution???
click ignore
Sorry....
I should have mentioned that XP just said it wasnt allowing installation of this hardware...no option of clicking anything!!
I havent run across this little bully boy tactic by XP before ...I thought I decided what I could or couldnt install?? -
there is an option in your pref. to allow or not allow ms approved software -- turn it off ....
some system admins will enable this - and in such cases dont turn it off (and you might not be able to)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I am relatively new to XP ...mostly did work on Macs
but now in setting up the PC learning the "extras of XP"...
I am set as an Admistrator in permissions on my machine...
So this a new bit of guidance for me...where are these preferences
you mention to be found ?? Appreciate any help in this area...
In installing these codecs ...one always has to be careful of conflicts
and them not working correctly...and its nice Microsoft has our interest so much to heart...but being able to control this restriction would be good..
So I am very interested to learn where to go in XP to be able to alter this
setting....just a few pointers would be good ..eg look under this section etc then in this area...any help as mentioned much appreciated!! -
right click on "MY computer" and choose 'properties'
click the 'hardware' tab
click 'driver signing'
click 'warn' or ' ignore' settings
click yes ' make this action system default' (add checkmark to box)
click apply and close --
thats it .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Trouble installing AC3 ACM codec on 64 bit OS
By Teemo in forum AudioReplies: 0Last Post: 30th May 2011, 15:42 -
AC3 Filter
By BobbyScot in forum Software PlayingReplies: 10Last Post: 28th Aug 2009, 09:54 -
ac3 filter settings questions
By THX-UltraII in forum AudioReplies: 0Last Post: 11th Feb 2009, 05:32 -
AC3 Filter playback problem
By look30 in forum Software PlayingReplies: 3Last Post: 20th Feb 2008, 10:38 -
Question about AC3 Filter...
By GangstaRap in forum AudioReplies: 9Last Post: 25th Sep 2007, 11:21
