Does anyone have any good tips on where to buy them and if the ink is any good? Thank you!
Results 1 to 23 of 23
hope this is a little more helpful than the earlier post !!!!!!
http://www.blankdiscshop.co.uk/acatalog/SVP_Communications_Epson_Printers_20.html
if your in the UK, it should be......
if not, try google.....
that is a LOT more helpful than the previous post. Thank you.
I don't think google owns an R200 and has purchased cartridges from the thousands of manufacturers and can therefore offer me advice on which is cheapest and most reliable. But yeah, it was a cool graphic. No doubt, stolen from an AOL chat room somewhere
IMO, p_l 's post was a little on the rude side. I serves no purpose to submit posts like that.
After clicking on p_l 's Google link, hit the "Froogle" button to find the cheapest source.Originally Posted by Noek
Personally, I use G&G ink, available from a number of online suppliers. I use my R200 strictly for CD/DVD printing, so I can't vouch for how G&G works for photo printing. I can say that I haven't suffered a single ink clog, and the discs I print look great.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
It may have been rude but he does have a point. You should have done some searching b4 posting this question. This forum alone has TONS on threads on ink for the R200...Originally Posted by Noek
that said, i get my ink from inkgrabber.com. it works great...The distance between genius and insanity is measured only by success... -
I think megatoners is the least expensive in the US, but I would read this before buying from them
https://www.videohelp.com/forum/viewtopic.php?p=1158869#1158869 -
OK, the pic was meant all in good fun. Sorry if it ruffled any feathers.
The link is to a Google search of this forum, which already contains a wealth of information directly pertaining to the question. It's a good place to start, especially when the poster's location is unknown. -
I also use megatoners and have never had any problems. They were the cheapest I've ever found at less that $4 per cartridge and free shipping IF you buy like $50 worth.
At resellerratings.com, megatoners is rated high for price and low for everything else, with an average rating of 4.32 out of 10.
Many thanks to all the recomendations, I will check them all out. And thanks to you too, p_l for keeping it interesting
It's a bit unfair - to be honest. Within the last 6 months, they've had 4 reviews, and a lifetime of only 22. So if only those people who had a problem post a review, then you'll get a bad rating.Originally Posted by sync
I can honestly say I've never had a problem with them. I received my package within a couple of days of ordering w/o a problem. The ink was good quality, haven't had any clogs yet - and I'm on my 3rd set of carts from them. The cart prices have dropped even further - less than $3 per. Time to order again! -
It's true that people are more likely to put in a rating if they are unhappy. But that's true for every company. The average seller rating is considerably higher. But as you say, they don't have many ratings and therefore their rating probably isn't a good indicator.Originally Posted by maldb
Well I never got my order from megatoners that I ordered Dec 13th. They said they would reship my order. I told them only to reship it if they were going to use express or overnight. They replied with, we will issue a credit back to your card. So here i am with no carts after 25+ days and my current carts are almost empty. I still have to find some place reliable and cheap to buy from. I have a email into blank-cd-cdr.com right now, so I may try them next
Wow! You really had a bad experience! Thank God my neighbor takes in my mail when I'm not home during the day.Originally Posted by stiltman
Try these places:
http://www.inkgrabber.com/printers.mhtml?search_for=Stylus%20Photo%20R200
http://www.inksite.com/printersgrid.php?PHPSESSID=bc0e683f63f1f9fadcbddf4b30129808&For...lus+Photo+R200
They're more expensive, but they're an option. Good luck. -
Do you guys happen to have any idea what kind of longevity you are going to get with these inks?
Also try here
http://www.monsterinkjets.com/CatList1.asp?id=261 -
As long as you don't leave your printed items out in the sunlight, they should be OK.Originally Posted by sync
Tests have shown that fading occurs with exposure to air and doesn't require sunlight. Tests also show that many third party inks, even those that look as good as Epson ink, have very poor longevity in comparison.Originally Posted by maldb
I've been using non-oem ink for years for my older HP printers, and everything I've printed still looks good. Will it last for 50 or 60 years? I don't know. I do know I keep my stuff out of sunlight - and they're not locked in airtight containers, etc. Sunlight will cause fading a heckuva lot faster than air, I can tell you that much.Originally Posted by sync
blank-cd-cdr.com has them for 25.75 after the 10 off coupon
Do Lexmark printers reject refilled ink cartridges?
By yoda313 in forum ComputerReplies: 14Last Post: 21st Oct 2012, 15:02 -
Canon CLI8 photo ink cartridges?
By kyrcy in forum ComputerReplies: 2Last Post: 28th Dec 2010, 14:06 -
Remanufactured ink cartridges from supermediastore.com?
By stantheman1976 in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2009, 11:03 -
Ink question for refillable Epson R220 cartridges
By Mahime in forum MediaReplies: 3Last Post: 14th Jan 2008, 21:54 -
Resetting HP Printer Ink Level for Refilled Cartridges
By galactica in forum ComputerReplies: 11Last Post: 5th Jun 2007, 05:21
