Hello!
I just used ImToo DVD Ripper to ripp a DVD and convert it to SVCD. And I hardencoded the swedish subs into the resulting SVCD. But the result was less then satisfactory. There where some fuzzy artifacts sorrounding the subs and basícally destroyed a good picture quality. Here is a picture that shows what I mean:
http://img91.exs.cx/img91/1930/freakyfriday6pp.jpg
is there a way to fix this in ImToo DVD ripper??
If not then I have to use another tool because when using TMPEnc to convert for instance AVi to SVCD with .srt subs I get perfect Subtitles without artifacts when encoded in by Direct VobSub. The point of encoding to SVCD from DVD rather then a DivX was to get great picture quality but the subtitles messes things up otherwise ImToo DVD Ripper would have been a great and easy tool to use!!.
But since this problem exists I have to use another method to get the subs in!. I am planing on using ImToo to convert to DivX instead of SVCD without the subs and then ripp the subtitles separatly using a different program and I want them converted to .srt subs!
So that I then can use it together with TMPGenc and convert the DivX to SVCD with permanent subs!.
So which tool should I use to ripp just the subtitles from the DVD and then convert them to .srt ones??
Results 1 to 1 of 1
Sincerely Joakim Agren!
Is there really no application that can ripp/save this video ?
By harry88 in forum Video Streaming DownloadingReplies: 4Last Post: 5th Mar 2012, 13:05 -
BD ripp for edition in vegas -
By Klemc in forum Blu-ray RippingReplies: 10Last Post: 4th Aug 2010, 00:48 -
Bluray ripp to lagarith 720x405 resize VirtualDub
By Klemc in forum Video ConversionReplies: 13Last Post: 4th Aug 2010, 00:45 -
what is the fastest software to RIPP into H264 ?
By james_patageul in forum DVD RippingReplies: 8Last Post: 12th Apr 2010, 13:46 -
ADVICE needed plz! As of Feb 08, best format to ripp DVDs? TIA.
By carapalida in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2008, 12:11
