Ive got 4 episodes of Mr Bean in OGG files that i would like to put on dvd for my son.
At the moment i can't even watch them on my pc,any help please.
You need the Ogg filter. http://tobias.everwicked.com/oggds.htm
Then you should be able to extract out the audio to WAV with Virtualdubmod. The video is often XVID. If you run the file through AVIcodec or Gspot, it will tell what it is. Then encode to MPEG-2 and author to DVD.
You can also download VLC Media Player and it should play them directly. -
Tobias' filters only support ogm and vorbis only ogg's. If it is actually an ogg file then it would contain say a theora video stream and vorbis audio.
ogm != ogg
http://www.illiminable.com/ogg/
VLC should work fine.
More than likely I guess though that you did mean ogm files.
how do you convert .ogg audio file to mp3?
By shun in forum AudioReplies: 5Last Post: 22nd Sep 2023, 15:34 -
How to easily convert .ts files to Mpeg2 or DVD
By renzo2000 in forum User guidesReplies: 0Last Post: 25th Aug 2010, 16:03 -
Best way to convert MKV files to MPEG2
By carlmart in forum Video ConversionReplies: 47Last Post: 6th Feb 2009, 00:08 -
batch convert .mpg (MPEG2) files?
By shun in forum Video ConversionReplies: 2Last Post: 8th Jan 2009, 08:44 -
How do I convert .MP3 to .OGG directly?
By Cobra in forum AudioReplies: 11Last Post: 9th Oct 2007, 14:04
