Hi
I have a VCD that I want to rip the Mpegs from and make them into a DVD.
VcdGearX trys for ages and in the end I have to force quit the program.
If I try to do a disk image from Toast 6 I get an error message saying:-
Couldn't complete the last command because there was an I/O error
( Your disc may be copy protected )
Result Code = -36
This VCD plays fine.
Is there anyway I can get the movie files from this disc?
Washac[/b]
Results 1 to 9 of 9
Hi Serbian
Thats it, problem solved, many many thanks, I now have the Mpeg
Washac -
a little known (apparently) method is to use toast 6, choose "Disc Info" from the "Recorder" menu.
a list of tracks will appear, you can select and save mpegs directly from here.
I've found this to be a very reliable and simple method.visit my photo retouching website: http://www.shiftstudio.ca -
I have the same problem of copying the files of this VCD to my harddisk but it keeps giving me the error "can not copy ... invalid ms-dos functions". What VCD Copy X tool did you try to mention? Please helpOriginally Posted by SERBIAN
Thank you Serbian, but this software work for Mac system only right? Unfortunately mine is Windows XP SP2 so I gues I can't try.
lingla
This is the mac forum. Try posting the same question in the General disccusion for PC users
You will only find Mac apps/help here.
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Aug 2010, 23:01 -
Problem ripping ET
By audax in forum DVD RippingReplies: 8Last Post: 27th May 2009, 18:19 -
CD Ripping Problem
By ThePMonkey in forum AudioReplies: 4Last Post: 25th Jun 2008, 06:47 -
Problem ripping CRASH
By vice86 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2007, 09:27 -
DVD ripping problem
By borisblavasky in forum DVD RippingReplies: 3Last Post: 17th May 2007, 11:38
