Results 1 to 15 of 15
    Jul 2003
    at home
    So I made a recording with my DVD/HD recorder from TV (using the external cable set top box), which is 16:9, but the TV will not be set to 16:9 mode automatically.
    I could change the TV mode to 16:9 manually, but this is not a perfect solution.
    My question: Is there an easy way or maybe some utility that can change some 16:9 flag in the VOB file without reauthoring?
    Cheers,
    JoachimS
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Check out ifoedit. There MAY be a restructuring option there. Though REAUTHORING would probably be the only course of action.....
    Kevin
  3. Two ways to do it on Mac. Try Pulldown X or do it with a Hexeditor. A tutorial is located HERE.
    Jul 2003
    at home
    So there is not really an easy way to do that without demultiplexing etc.?
    Cheers,
    JoachimS
  5. Not that I know of, but it was authored with an incorrectly set flag so it seems you would want to reauthor anyway. It's not like you lose quality by demuxing and re-authoring.
    Jul 2003
    at home
    Will it work if I demuxed each VOB separately, set the flag in the m2v file and muxed it again? It is not single VOB.
    The video was made with DVD Recorder.
    Cheers,
    JoachimS
  7. Funny, I just have answered the same question on a french forum.
    myDVDEdit can do that
    -With your DVD on your hard disk, open it with myDVDEdit
    -Select the VTS file which contain the recording (VTS 1, I think)
    -Click on the IFO tab
    -Change the Aspect option from 4:3 to 16:9 auto letterbox
    -Save, test, burn... that's all.
    Jérôme.
    myDVDEdit, the DVD resource editor.
    myDVDEdit, l'éditeur de ressources du DVD.
    Jul 2003
    at home
    myDVDEdit worked! Thank you!
    Cheers,
    JoachimS
  9. Excellent. I had the same problem. Someone gave me a DVD that was improperly flagged. I kind of figured I was stuck since I don't have any authoring software. Sounds like this should do the job.
  10. Off topic, but I thought John Yaya would be interested:
    The Return of the Banzai Institute?
    Dec 2004
    San Rafael, CA
    OK. I must be doing something dense. I just downloaded myDVDEdit, and I can't get it to open anything. I've tried the actual disc, a copy of the VIDEO_TS file on the computer and a mounted disc image. I try "open" on each, and the program ignores me. What am I missing here?
  12. myDVDEdit can't open CSS protected DVD.
    Is it the case ?
    Jérôme
    Jul 2003
    at home
    I also ran accross a small problem: I did not have file permissions (some files protected, cannot be saved etc...) to edit the files in VIDEO_TS.
    I quickly changed my access privileges from read-only to read/write for the VIDEO_TS folder including all files contained therein.
    After that I could do the trick with myDVDEdit as described.
    Cheers,
    Joachim
    Dec 2004
    San Rafael, CA
    The only thing wrong was the working of my head that late last night. (Yawn) No, it wasn't a protected disc. It was a file from my Panasonic stand-alone recorder. All I had to do was quit and re-launch the program and everything worked as advertised. (I, too had to re-set the write permissions on the VIDEO_TS components before I could change the flag.)
    This is a great solution for the home theater crowd. ($ contribution to follow) I have a lot of widescreen movies recorded from HiDef down-converts using a stand-alone DVD recorder. The results are beautiful - almost commercial DVD quality - but the recorder flags everything as 4:3. This is no problem when playing back on my widescreen display, but on most 4:3 TVs there's no way to get past viewing them as very thin, squished people.
    I'm going to spread the word on this over at AVS forum, though - sadly - most of them don't use Macs.
  15. Off topic, but I thought John Yaya would be interested:
    I'm horrified you would post a link to something touting such an evil individual as Buckaroo Banzai. I am not the only one who sees a corrolation between his appearance here and not only the disappearance of our esteemed and revered CEO, but also the decline of a fine corporation which had a reputation for employing many individuals with somewhat unusual backgrounds. The mere sound of his name gives me shudders. Plus, it took a lot of work to repair the big hole he left in our building.
