Is there anyway to extract each channel of a 5.1 surround mix in a DVD, of a particular chapter?
What tool should I use?
Hello,
YEP!
Use dvd decrypter in ifo mode. Select stream processing and choose the 5.1 track you want. Then you'll rip just the audio to a file.
Use besweet with besweetgui and you can convert the vob or ac3 to "six-wav payload" which will give you each individual channel in a mono wav file
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Revisiting an unresolved (?) issue, re: extracting 7.1 channels...
By takearushfan in forum AudioReplies: 4Last Post: 30th Mar 2012, 05:06 -
Premiere Pro ignores surround channels in 5.1-channel wav
By Asterra in forum AudioReplies: 14Last Post: 11th Jul 2011, 19:58 -
Convert MKV to WMV w/5.1 channel surround?
By Spdngblt56 in forum Newbie / General discussionsReplies: 14Last Post: 21st May 2010, 02:11 -
No Right Surround Channel when transcoding AC3 -> WAV
By SliceOfHorse in forum AudioReplies: 8Last Post: 21st Aug 2009, 16:29 -
Extracting WMA channels
By zuja9 in forum AudioReplies: 9Last Post: 27th Jan 2009, 04:53
