i have the ac3 filter installed and also tmpge sound player and soft encode but my ac3 file icons are not recognized as anything or associated or whateever,,,any ideaqs why???
Results 1 to 10 of 10
Hello,Originally Posted by catdaddio6
Why do you need it to show up as a different icon??? What are you doing with it???
Programs will accept .ac3 files regardless of what windows shows as long it is a real ac3 file.
i have the dolby softcode ac3 encoder,,the file looks like an unrecognized icon and if i click it i get the windows dont know what it is thing,,but i can drag and drop it into a player and on a couple it will play,,but on others it wont,,there has to a reason for this
You probably have the byte order wrong. Try switching from Intel to Motorola or viceversa and see what happens.
Sorry, I had to go see about a girl -
you said you have soft encode, right? In the encode setting page, there's a box that reads "save frames in Intel byte order". Try changing that and see what happens.
I think catdaddio is having a file association issue. If im correct I think he wants his ac3 files to be associated with softcoder.
If this is what youre talking about, then right click on any ac3 file, choose "Open with...", then select softcode or what ever program you want your ac3 files to open with from the list (or browse for it if it dosnt show on the list), make sure the check box that says "always use the selected application to open this kind of file" is checked. and click ok.
RAM not recognized
By videobread in forum ComputerReplies: 4Last Post: 27th Nov 2011, 12:34 -
AC3 Audio Not Recognized in Machete
By bseos in forum Video ConversionReplies: 2Last Post: 13th Oct 2011, 03:02 -
BD-Rs are not recognized
By orfajackson in forum Newbie / General discussionsReplies: 1Last Post: 23rd May 2009, 18:43 -
New HDD not recognized
By CSULB71 in forum ComputerReplies: 18Last Post: 19th Apr 2008, 21:21 -
Cd-r not recognized
By cd090580 in forum DVD & Blu-ray WritersReplies: 14Last Post: 27th Feb 2008, 04:03
