Dear Friend,
I'm a newbie here, and i want to ask you about how to capturing from camcorder, i got a TV Tuner with the Video Input (RCA) & S-VHS Input, but there is no Audio Right&Left Input there (RCA).
My Question is :
1. How can I Capture the video dan audio from my camcorder for make it into vcd ?
2. Where I can put my Camcorder audio line out connected into my PC ? so the sound also can be capturing.
3. What software i must used ?
I Hope Somebody can help me and teach me step by step so i can understand. Thank You.
Your card should have came with a loop cable.
What it is is a cable that goes from your composite L/R Audio to a mini-jack that loops to you Audio card mic-in or "line in".
And if you go to your settings for your audio you change your recording to whatever device you are using.
Is my PC up to capturing from my camcorder?
By alhenderson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 21st Sep 2009, 02:54 -
Capturing from DV Camcorder
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 23:16 -
Capturing Xbox 360 in HD using HD camcorder?
By infzer0 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2007, 15:25 -
Does capturing with a camcorder really damage it?
By IL_video in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 22nd Nov 2007, 09:31 -
Capturing from camcorder
By Confused Chimp in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 13:09
