Hi,
I use TMPGenc to convert my avi files to mpeg for burning. When I go to play in my DVD player, the movies have some problems. The sound and picture usually goes off sync. The picture will speed up really quickly for a few frames, then go back to normal. Eventually the sound will catch up with what is being said. This happens throughout the movie. I was wondering if anyone knew how to fix this and if they could explain it to me simply =) I think it is probably a problem in the conversion process. Any suggestions would be more than appreciated.
Thanks for your time.
Does this happen when you play the VCD on your computer too?
I only dream in black & white...
MSN: paschendale@gmail.com -
may want to try a couple different brands of cdr's, also I found this happened when I use to burn my vcd at to fast a speed, Have not had this problem since I slowed my vcd burn speed to 8x.
Audio out of sync after conversion
By user2008 in forum DVD RippingReplies: 5Last Post: 13th Nov 2010, 06:13 -
Conversion out of sync
By whiteshoes in forum Video ConversionReplies: 47Last Post: 27th Nov 2009, 02:35 -
After conversion audio is out of sync
By videojunkie7 in forum Video ConversionReplies: 0Last Post: 23rd Nov 2009, 19:06 -
Audio Conversion out of sync
By Silsur in forum AudioReplies: 8Last Post: 13th Oct 2009, 18:45 -
Conversion out of Sync, probably cause=FPS?
By Day44 in forum Video ConversionReplies: 2Last Post: 7th Jul 2008, 15:30
