    Jul 2003
    California
    I have used VOB Blanker to delete certain parts of a DVD. I identified those parts using DVD Shrink. Everything seemed to work fine (blanked out those titles that I did not want) until I played the back-up DVD. The parts were in fact gone, however, there was no audio throughout the entire DVD. I did not change any of the settings from the default mode. Does anyone know why this may have happened. Is it possible I could have avoided this by using the skip function on those titles that I wished to keep?
    Thanks for any help.
  2. Member jeanl's Avatar
    Sep 2004
    CA, USA
    cr8zycat, try to post your problem here, jsoto, the author of vobblanker is very active there. He might be able to help you.
    Jeanl
    MenuShrink a free tool to shrink menus into stills with or without audio!
    DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
  3. It happened to me as well on one particular title and didn't notice it until I burned the DVD and tried it in my player. Loaded the ISO image still on my HDD in Alcohol 120% and it was faulty as well. I simply just did it over again and all worked fine. Just assuming a small glitch on my system.
