Why do I get the sneaking suspicion that you never bought DVDRemake Pro ?Originally Posted by skip2mylou
Results 31 to 60 of 61
@ ZippyP.
however when i try to Open the Video_TS folder of one ripped and compressed DVD, it goves me a list of tracks and i have to choose, how can i just add the whole folder, menues and all?Wow! You got shocks, pegs... LUCKY! -
@ Jimmalenko
because i didnt...Wow! You got shocks, pegs... LUCKY! -
You must merge the 2 with DVDRemake Pro and then use DVDShrink on its output if you want the original menus to work properly. That is the only way, barring being a guru with IFOEdit ...If in doubt, Google it. -
@skip2mylou, what exactly do you want?
jimmalenko has bent over backwards for you but you don't understandand he has clearly stated options along with everyone else. If you want original menu's after joining then unless you are a guru you cannot really do it simpler than the few clicks in DVDRemake PRO
I know you can rebuild the DVD's with an authoring program but then you lose the original DVD workings unless they are simple menu's with a Play/Chapter option. Again time & knowledge is something to look at
as for quality issues, people with dual layer burners won't see as much quality loss when joing 2 DVD9's -
@MackemX:
Here's the gist of it as I understand it:
OP:
Originally Posted by jimmalenko
So basically I don't think we've progressed anywhere throughout this whole thread, since we're still at the point where we need to:
Originally Posted by jimmalenkoIf in doubt, Google it. -
ok thats fine thanks jimmalenko. Ima learn how to use IFOedit, then do what i need to do, call me cheap, but i don't wanna pay, as simply as that, for a software to do what i need. but since i do lack A LOT of knowledge in the art of DVD making, i guess that maybe i should spend some time and become and IFOEdit guru, that might give me a whole new perspective in life, you never know...
@ Mackem X
what i exactly want is 2 dvds with their original menues on one dvd, with the best quality i can achieve, and the easiest way to do it.
@ jimmalenko
im sorry i didnt express my gratitude but i really am grateful for all your advice and how youve helped me, believe it or not, ive learned some cool stuff.
@ everyone
i would like to thank you for all the posts that have been submitted, every one of them have progressed my project along in some way or another, so thanks.Wow! You got shocks, pegs... LUCKY! -
you know what, you're absolutely right
but if there is a way to achieve exactly what i want exactly how i want, ill find it...
o well i guess theres no hope if i have to guess i just have to buy DVDRemake Pro...
trust me skip2mylou when I say it is very hard to join 2 original DVD's keeping original menu's. You will get people saying use authoring programs but I have never come across an easy way to recreate any 2 DVD's into 1 merged DVD easily
I wrote a couple of guides HERE on how to do it before it was automated using DVDRemake Pro. The thing is it also used DVDRemake Pro. If you are just doing one join then think about whether it's worth the price just for this feature. It does have many other features but it all depends on how you backup DVD's as to whether they will be useful to you
@jimmalenko, I know what you are thinking. There is many a time I have found out new ways so I guess I'm like skip2mylou. I will look for other answers even though the solution is slapping me in the face with a big wet fish
. Saying that I have come across some interesting things by looking for new ideas/methods and gladly shared a few
I thought I held back pretty welll ...If in doubt, Google it. -
There's one other way (possibly) around this. (Shoot me down if I'm totally mistaken)
Get the two dvds shrunk so they both fit on one dvdr, then author in DVDLab Pro, which will accept two VTS...
Either way, you're probably going to have to actually buy some software it seemsCheers, Jim
My DVDLab Guides -
Originally Posted by reboot
I played around with DVDRemake Pro last night and it truly is the easiest way to do this. Open disc 1. Open disc 2. Go to Tools > Merge DVDs. Press OK. Press Export DVD button. It'll do the rest. Shrink the output and burn. VERY easy.
... although IMO the default menu does kinda suck ... I can see why there's a guide to replace itIf in doubt, Google it. -
yep it is easy isn't it, especially if you can appreciate how complicated it would be to do it manually with current tools, if at all!. Imagine trying to join The Matrix with The Pirates of the Caribbean. I'd rather buy a multi disc DVD changer and buy extra copies of the DVD's!
the default menu does suck (badly) but I'm sure in time there will be a selection. I always suggest that people use something like GUI for DVDAuthor or similar. You can create a new menu with this for free if people don't want to buy extra authoring software or don't already have it -
), so I'm gonna have to read some guides, and probably 4 out of the last 6 or so of your posts, MackemX
might want to read the thread about 3 dvds to 1
I created my menu with TDA -
http://www.dimadsoft.com/dvdremakepro/ht_customize_menu.php
should save you a little time on the learning curve. As usual the bark is worse than the bite
BTW, I knew what I was doing in creating the menu with TDA -
Originally Posted by stiltman
IMO that's got all the useful answers in itIf in doubt, Google it. -
No I was think the 3 to 1 that you just posted in
But now that you posted a link in the other, looks like I need to post in that one too -
How's about you post a link to the thread you think I should read
I know about this thread:
https://www.videohelp.com/forum/viewtopic.php?t=249503
Which other one do you think has some good information ?If in doubt, Google it. -
yeah that's it....
clear as mud.....I know...I know READ READ
<time for my medication> -
your welcome mate
, it's nice to get the odd thanks now and then
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
How to put a lot of movies into single DVD
By TheEmperor in forum Authoring (DVD)Replies: 9Last Post: 19th Sep 2009, 11:48 -
want to put home movies onto dvd
By shashgo in forum Newbie / General discussionsReplies: 2Last Post: 30th Apr 2009, 09:14 -
why could I only put two movies on a DVD disk when I use Nero to burn DVD?
By efang622 in forum Authoring (DVD)Replies: 7Last Post: 24th Oct 2007, 08:40 -
How many Divx movies should I put on one DVD+R?
By Hank Kinsley in forum Newbie / General discussionsReplies: 11Last Post: 17th Aug 2007, 03:39
