Hello everyone, i have ripped a few DVD with their menues and all, and i was hoping that maybe there is a way to fit 2 DVDs on one disk keeping the menues and extras and all. i was hoping to you know have the initial menu on the output disk have like one button for each movie, then after i click one button, the next menu would be the menu for the actual movie (play, extras, etc.). however, i want the second menu to be the same as on the originial disk, possible?? plus i was also hoping to keep movie qualitie at the highest possible. HAPPY POSTING!!
-skip2mylou
Results 1 to 30 of 61
Wow! You got shocks, pegs... LUCKY!
This has been raised at least 6 times in the last month, but I guess if you'd done a forum search, or browsed through the forums, you'd know this already
The consensus has always been that DVDRemake Pro is the only software that can do this.If in doubt, Google it. -
Yes, you cam do it. DVD Remake Pro can do this out of the box. Check out the guides for it here https://www.videohelp.com/tools?tool=DVDReMake_Pro
Remember that trying to fit two movies onto a single sided, single layer DVD -/+R will require a lot of compression, and will compromise the quality substantially.Read my blog here.
If you don't care about quality, rip the vobs, and re-encode using the kdvd template for half D1, fit 8 full length movies on one dvdr.
Cheers, Jim
My DVDLab Guides -
Originally Posted by rebootOriginally Posted by skip2mylou
DVDRemake Pro I sayIf in doubt, Google it. -
thanks, so i can not have the original menus and the qualtiy will be lowered. will the quality become THAT bad, or like noticably less sharper, but still decent and wont take away too much from the veiwing satisfaction? thanks.
Wow! You got shocks, pegs... LUCKY! -
A quick realization of Disk size and Movie size would give you the answer. As cheap as media is these days, I would have to ask "Why"?
Originally Posted by jdizzy40"Art is making something out of nothing and selling it." - Frank Zappa
i checked the guides, and 1 says how to merge DVDS but the original DVD is like 2 GB, so they are 2 DVDs, merged become around 4 point something GB. so can anyone advise how to fit 2 FULL length DVDs the 4.7 GB's ones, onto ONE DVD. happy posting.
-skip2mylouWow! You got shocks, pegs... LUCKY! -
ive done it before by shrinking each movie on dvd shrink and then putting the already shrunk file in to be shrunk again that makes them small enough if u dont care about quality much
Originally Posted by jimmalenko
skip2mylou, I would say using DVD Remake Pro will do that job for you.... I, myself just made it couple days ago to join 2 DVDs with every features from original DVDs... But I had to make the NULL DVD with the designed menu as I wished by using SONIC MY DVD software (you can use NERO or any software included in your burner) then I just followed the guided from DVD Remake Pro site. Good luck! if you plan to do it... -
For whoever asked why you would do this:
I bought DVD Santa, so encoding these wedding videos I shot as DVD is a snap. Now all I want to do is have a menu to choose among them, or the slide shows (also by DVD Santa) . I may buy an authoring tool, but if DVD Remake Pro (I already own this) makes it easier, then it saves me time, and possibly money.
As far as backups go, I once backed up my 2-disc set of Shrek one with wide-screen movie only on one disc, and extras from the two discs merged into one (with menus - the movie button on the main menu from the wide screen disc would swithch to the main menu from the full screen disc, and vice versa). Wish the one-click feature was around back then, it took me 3 hours of editing, using a guide and a spreadsheet... -
also i wanted to ask jimmalenko:
the guide for DVDRemake Pro says that when merging the 2 discs, the original menues stay, so after i use DVDShrink, will the original menues still be there, also can u please link a guide from the DVDShrink operation, thank you SOOO much!
http://members.dodo.net.au/~jimmalenko/DVDShrink32.htmIf in doubt, Google it. -
hey um i just merged the 2 DVDs on DVD Remake Pro, but the export button is not working because it is a demo, what other tool can i use to export a merged DVD?
or how can i make this work??
Originally Posted by skip2mylouIf in doubt, Google it.
i used DVDShrink to compress, however, when i removed the unused languages and subtitles, the estimated file sizes would not be accomodated onto one disk (example, one is to be 3,600 mb, and the other 2,800mb) so what do i do now to be able to accomodate them onto one disk?
how do i load the new file< "open files"?
Do it the same way
Go to File > Open (or click the Open Files button), and point DVDShrink to the folder that contains the output from DVDShrink the first time around. If you let DVDShrink create an ISO Image, then go to File > Open Disc Image isntead.If in doubt, Google it. -
Learn to use IfoEdit and VobEdit, and then reencode the video streams as kdvd, or any other methods, if you prefer.
You'll easily fit 2+ movies with all menus and everything on one DVD.
Check here: http://www.doom9.org/guides.htm
And look under "DVD Backup (Full Guides)"
This is not a "One Click" (newbies) solution. It's an advanced "Not-for-the faint-of-heart" user. So be aware of that.
Guess how I encoded my "Star Wars Trilogy" on one DVD -
Using KDVD templates, I put Star Wars (3 movies), Superman (4 movies), and Shrek all on one dvdr
Roughly SVCD quality, minus all the menus etc. Authored in DVDLab.
This is not a "One Click" (newbies) solution. It's an advanced "Not-for-the faint-of-heart" user. So be aware of that.Cheers, Jim
My DVDLab Guides -
appreciate the help i have one question for jimmalenko however, i have compressed the DVDs to my desired size on DVDShrink, and i was wondering, instead of merging them, can't i just burn the 2 sets of VIDEO_TS and AUDIO_TS on one DVD. i will use NERO to burn them, so cant i just create a TITLE menu with it which have buttons for the different DVDs?
or if i do have to merge them, what else can i use. i saw that TMPGEnc DVD Author will merge disks i just dont know how. i tried a guide link but the link is dead. any one know how to either merge with TMPGEnc DVD Author or maybe with another freeware??
Use TDA and select "add dvd video" to input each disk as a seperate track.
"Art is making something out of nothing and selling it." - Frank Zappa -
so i start TDA, New Project, Add DVD video, Open the Video_TS folder of one ripped and compressed DVD, then what do i do?
dvdauthor.htm]This guide[/url] should help, even if it isn't exactly what you are looking for it should give you enough to accomplish your objective."Art is making something out of nothing and selling it." - Frank Zappa
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
How to put a lot of movies into single DVD
By TheEmperor in forum Authoring (DVD)Replies: 9Last Post: 19th Sep 2009, 11:48 -
want to put home movies onto dvd
By shashgo in forum Newbie / General discussionsReplies: 2Last Post: 30th Apr 2009, 09:14 -
why could I only put two movies on a DVD disk when I use Nero to burn DVD?
By efang622 in forum Authoring (DVD)Replies: 7Last Post: 24th Oct 2007, 08:40 -
How many Divx movies should I put on one DVD+R?
By Hank Kinsley in forum Newbie / General discussionsReplies: 11Last Post: 17th Aug 2007, 03:39
