Everytime i double click on the installer for it it loads up the wizard...loads some things and then the actual Installer tryies to loads and i get a box with a button on it "OK" saying
"This installation package could not be opened. Verify that the package exists and that you can access it, or contact the application vendor to verify that this is a valid Windows Installer package."
I have restarted my computer many times. Downloaded the trial from all kinds of sites. But now im stuck. I really want to use this progrtam to put some avi movies on a dvd to play on my tv. If you can help id really appreciate it.
Try the DVDLab trial instead...Just a suggestion.
You might need a virus scan, if the original download won't install. If this is XP, log on as Admin and try again.Cheers, Jim
My DVDLab Guides -
i got dvd lab and its a little confusing...if theres any other way to get the tmpg dvd author it would be great.
I downloaded it on my other computer and transfered the files in c:/program files/TMPGEnc DVD Author to my computer. It ran but it couldnt burn the dvd.
any other ideas? -
That happened to me when I bought it. I just downloaded it again and it was cool.Originally Posted by corn_planter
um...confusing? So is tmpgenc dvd author...tutorial in my sig for dvdlab
Cheers, Jim
My DVDLab Guides
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
TMPGEnc DVD Author 3
By WHISPERS1944 in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2008, 04:56 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
