Hi
I have windows xp and MovieMaker 2 but when I try to load the mpeg file it crashes. How can I convert mpeg2 file to DV AVI using the Microsoft DV AVI codec? (Microsoft DV AVI is not presented in the codec list of virtualdub).
Results 1 to 10 of 10
Install the Panasonic DV Codec and that will work in Virtualdub
the MS DV codec is the worse DV codec on the planet
I don't know if it's the best, but it's pretty damn good.Originally Posted by kuptonThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
in Adobe forum thay said tht MS is better.i would like to know why thay think that way...
There is a slight variation in the way the DV looks, depending on what codec you use and different people have different opinions on which look they like. The Panasonic codec is used by many and its free. Try it and see what you think.Originally Posted by samifoxHave a nice Day
Originally Posted by jimmalenko
weird that they would say that as in thier own lit. they switched from using it (premiere 5) to a proper one ...
anyway - if you search around you will find several very good DV codec comparisons and the MS one is always rated the worse ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
Converting from xvid avi to mpeg-2
By busbee2 in forum Video ConversionReplies: 5Last Post: 13th Dec 2009, 00:44 -
converting mpeg to avi
By extremebeat in forum Video ConversionReplies: 1Last Post: 24th Feb 2009, 14:07 -
Converting MOV -> MPEG-2 (or AVI or...)
By Sean-PH in forum ffmpegX general discussionReplies: 5Last Post: 10th Jan 2008, 14:35 -
converting avi to mpeg-1 help plz??
By darealest1 in forum MacReplies: 5Last Post: 12th Jul 2007, 22:43
