I tryed to copy a DVD using EasyVCD and DVDx that had multiple episodes on it. With EasyVCD (v1.1.5a) I only got the last episode as a CUE/BIN. With DVDx, I only got the 1st as an mpeg.
Am I doing something wrong, or do I need more tools?
Thanks in advance.
<----Look to the left under all guides. Find the ones pertaining to DVD authoring. Follow em.
EazyVCD will only do 1 title at a time. If you're doing an episodes disc, then you need to do each episode 1 at a time. I'd suggest setting the output to "Make MPEG File", and then you can combine multiple episodes later on when authoring. The problem you're going to face comes when you try to set a custom size for each episode, which you can't exactly do in EazyVCD. You might need to look at http://members.dodo.net.au/~jimmalenko/TMPGEnc1CD.htm , and when you get to setting the size of the output files in TMPEnc, if you want say 4 episodes per disc, then set it to fill 25% of the disc for example.
If in doubt, Google it.
Cannot preview titles and chapters
By YonB in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Mar 2010, 15:23 -
How to convert Titles to Chapters
By Psymon007 in forum Newbie / General discussionsReplies: 14Last Post: 11th Jun 2009, 18:20 -
FAVC - How to make chapters instead of titles ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2008, 14:03 -
How to merge several chapters or titles together
By guns1inger in forum DVD RippingReplies: 0Last Post: 26th Dec 2007, 22:25 -
Episodes from Several DVD's Onto One With Menus and Chapters
By Savutay in forum Authoring (DVD)Replies: 0Last Post: 12th Oct 2007, 16:41
