Just replaced my 2.53Ghz CPU with a 3.06Ghz CPU. Used old heatsink/fan with no paste or anythng. New CPU idles around 34C but shoots up to 62C after encoding for awhile. Any recommendations for a new heatsink/fan? Don't want to use the old one as I intent to upgrade an older system with the 2.53Ghz components. Thanks in advance.
wwaag
http://thermaltake.com/coolers/comboCool/pipe101/pipe101.htm
This is the one I have, but it is huge and heavy.
http://thermaltake.com/coolers/comboCool/cl-p0024tower112/cl-p0024tower112.htmOriginally Posted by lordsmurf -
I use a Thermalright SP-94 with mine (they don't come with fan).
http://www.overclockers.com/articles373/p4sum.asp has some tests
on various heatsinks - though it doesn't look like it's been updated for
a little while.
J -
I use Swiftech heatsinks on my 3.06s. They don't top 50°C during long encodes unless the ambient temps are pretty warm (better than 30°C). I've got Panaflow medium-speed 80mm fans on top of them. If you aren't overclocking you could probably get away low-speed fans like the Vantec Stealth and save on some noise.
FB-DIMM are the real cause of global warming
Question about solid state cooler as in 12 volt car refrigerator
By jimdagys in forum Off topicReplies: 1Last Post: 8th Mar 2011, 20:48 -
Corsair Hydro H50 CPU Water Cooler
By stiltman in forum ComputerReplies: 5Last Post: 30th Sep 2010, 22:47 -
Anyone using a P4 3.06GHz / 1M / 533 SL7DT 478pin CPU
By blinky88 in forum ComputerReplies: 13Last Post: 2nd Sep 2008, 12:47 -
Heat pipe dirction for CPU cooler
By stiltman in forum ComputerReplies: 25Last Post: 13th May 2008, 21:13 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 20:33
