If I have the opportunity to get a file in DVDR format vs. AVI format, which should I expect would be better quality. DVDR is usually a lot bigger, but I don't mind waiting for better quality. I'm guessing the answer is that "it depends," but is there a general rule of thumb to tell? Thanks.
I think the best answer you can expect is "it depends".
Depends on the resolution of each, depends on the bitrate, depends on the codec used, depends on the audio format.
It just depends...
For portability, I would say converting everything to DVD (MPEG2) would be your best option. If you want to ratain the best quality ad don't mind only being able to play it on your PC, an AVI using the XVID codec might be your best option. I've been impressed with some XVID format movies that I've seen.
Join or Combine 2 AVI files with no quality loss.
By deadnuttz in forum EditingReplies: 18Last Post: 21st Sep 2016, 03:09 -
Add text to MKV or AVI files...Without loss of quality...
By jaseemkannur in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 05:36 -
how do I convert .divx files to .avi without loss in quality
By Onceler2 in forum Video ConversionReplies: 2Last Post: 17th Oct 2009, 11:03 -
Quality problems after merging two .avi files
By Metallo in forum EditingReplies: 14Last Post: 13th Aug 2008, 10:50 -
relative quality and best burn speeds for some popular media
By JohnnyBob in forum MediaReplies: 32Last Post: 8th Feb 2008, 18:44
