Hello all,
I have run into a problem. I have three VCDs which i want to put onto one DVD. I copied the mpeg's from the cd's onto the hardrive and using the latest version of Nero6/Nero VisionExpress3, I made a dvd (single layer). I wanted the Dvd to have 4 simple menus. The main menu shows links for the 3 VCDs. Each of these links takes you to a separate menu page where there are links to chapter points. Everything worked flawlessly, the videos were transcoded in about 3 hours and i was happy until i popped this into the dvd player.
The Main meny works fine; each of the buttons takes you to the appropriate secondary menu. From here i run into problems. None of the secondary menus work. When a selection is made, the player either freezes or the "stop" funtion is activated. I have never been able to create successful menu's with Nero. What gives?
After this i decided that I will use Adobe Encore to do the job but it is very picky about the kind of files that it will import. I tried importing the vob files from the dvd i just made but Encore doesn't import it saying that the resolution doesn't match. So i decided that i will use the latest Tmpge xpress to convert the mpeg files into acceptable format so that i could import them in Encore. After carefully setting up the settings so that all the video content would fit on a 4.7GB disc, i let it encode but Tmpge crashes before completing the job.
Now i am not sure what to do. Nero is able to transcode the files and make a dvd but the menu's don't work. Adobe Encore won't accept the files and TMPGe freezes in the trancoding process. I am confused why one app is able to transcode while the other is not. Any ideas on what i should do from here?
Results 1 to 11 of 11
yeah i just copied. But does it make any difference? the video is low resolution so even if i use ISOBuster, Encore still wouldn't accept them right? And the deal with Nero being able to transocde and TMPGe Xpress not bein gable to transcode. What about that? r they connected?
Try taking a look at this thread which explains the whole process. -
What I do with low resolution material is I convert 352x288 px, 44 kHz to 352x576 px, 48 kHz with TMPEGEnc Plus. This is DVD compliant (named Half D1). After that I create a menu and DVD image with DVDLab, but I guess you can use any other program if you created compliant MPEG2 files.
Note: If you created VOB files and want to use the MPG files within, you don't have to reencode, but you can demultipex them (e.g. with TMPEGEnc Plus).Music was my first love, and it will be my last -
I use VCDGear to do the DAT->MPEG extraction, then just drop the files straight into TMPGEnc DVD AUthor. No conversions necessary at all.
If in doubt, Google it.
Help with unique editing situation.
By BillThomas in forum EditingReplies: 1Last Post: 18th Feb 2010, 13:49 -
Current Situation re. +R and -R
By nlec in forum MediaReplies: 1Last Post: 23rd Sep 2008, 15:59 -
Strange situation regarding an AVI file
By hyphenate in forum Newbie / General discussionsReplies: 5Last Post: 11th Mar 2008, 10:02 -
Which authoring software is right for my situation ?
By ahmadka in forum Authoring (DVD)Replies: 5Last Post: 27th Feb 2008, 19:10 -
It was a stinky situation...
By zzyzzx in forum Off topicReplies: 3Last Post: 18th Jan 2008, 14:27
