Results 1 to 15 of 15
  1. Anonymous
    Guest
    I just found this feature.Without tivo you can record programs and play them back later.Does anyone else use this function?
  2. Anonymous
    Guest
    What?
  3. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Are you talking about capturing to your PC? What are you using to record?
    Nothing can stop me now, 'cause I don't care anymore.
  4. Banned
    Sep 2004
    Inner Circle of Thought
    Comcast has a cable converter box that has the pvr in it.
  5. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Originally Posted by Dr.Gee
    What?
    A lame attempt at a funny
  6. Anonymous
    Guest
    I dont think that is the case.I think it is like "on demand" feature.You can pause/ff these programs.
  7. Banned
    Sep 2004
    They are starting to do on demand stuff, but they also have a pvr converter box.
    I talked to a rep not too long ago about it.
  8. Anonymous
    Guest
    really?,I've had this box for a year and a half.
  9. Banned
    Sep 2004
    It may not be available in your area yet, but stay tuned.
    Time Warner has had the pvr boxes for a little while.
  10. Anonymous
    Guest
    well i can record
  11. Banned
    Sep 2004
    well i can record
    Yes and pause and FF and Rewind live TV.
  12. Anonymous
    Guest
    I just called comcast.I cant actually record even though it appears so with my current box. I might junk the tivo. Tivo cant store HD and this will store up to 30 hrs HD and 120 non-hd.For 9.99/month.Thats cheaper than tivo and you dont have the equipment layout.
  13. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    HACK THE TIVO!!!!!
    Drop in a 400gb harddrive and dump it to your pc for dvd burning!!!!
    Kevin
  14. Anonymous
    Guest
    Called to cancel tivo and they dropped my rate from 12.95to 6.95
