I'm trying to play my own created vcd and I'm having no problem creating and burning and even tried it at Radio Shack on a RCA dvd player, with sucess. My problem is My player tells me "no valid disk" . I've recoded my Oritron 100 several times and even learned that I had to enable software update after entering codes. I'm still in the dark. My latest burned vcd I used SmartDisk MVP progam it used VCD 2.0 software and encoded properly I'm also using Memorex Platnium CDRW disks. Please Help.
The problem is probably your DVD Player won't recongize CDRW. Trying burning with CDR's.
I've tried using CDR also. I just recently noticed that most of the users of this machine are successful with CDRW.
Just in case you are not aware of this but the oritron machines do not play VCDs by default (due to a licensing problem with Philips).
You have to switch on this function via a hidden menu (you can also make it a multiregion player via hidden menus too).
If you havent done this then even offcial factory made VCDs will be rejected as invalid - I think this is your problem as it does play CDRs OK.
http://allvols.virtualave.net/index.html - should provide you with the info you need.
Steff
some will play and some wont.
By kushy66 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2011, 22:32 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
xp wont play movie
By natty in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2010, 13:26 -
8x DL wont play in PS3
By Onceler2 in forum MediaReplies: 3Last Post: 6th Aug 2009, 15:16 -
My pana s97 and pana ex75 wont play my vcd's correctly
By ozizu in forum Newbie / General discussionsReplies: 0Last Post: 10th Jul 2008, 23:32
