Is there some way to rip songs that are played in menus on DVDs, to WAV?
The music is played as a menu on a DVD instead of using a video file. DVD decrypter doesn't seem to have the ability to do menus.
Grenge
"Don't look at me. I'm irrelevant." -
Menus are contained within VIDEO_TS.VOB and/or the _0.VOB files (VTS_01_0.VOB, VTS_02_0.VOB, and so on .... ). Try ripping these files in file mode with either smartripper or DVDDecrypter, then demux the files using VOBEdit. This should give you the menu's audio, most likely in AC3 format. From there you can convert to WAV in any number of programs, with AC3Tool being my recommendation.
If in doubt, Google it.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Add audio won't work in audio menu.
By petwes in forum AudioReplies: 0Last Post: 21st Jan 2012, 08:59 -
Ripping Blu Ray Disc to DVD with same menu and chapters
By MI6 in forum Blu-ray RippingReplies: 2Last Post: 10th Sep 2011, 09:35 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 19:37 -
audio ripping
By zinc in forum AudioReplies: 3Last Post: 24th Apr 2008, 15:41
