i gotz anime i want to convet to vcd but its in rm. format. i tried to use tinra with tinraGUI to convert it to avi. by simply selecting the file and press convert. after its done. it bout 2 gigs. i try to play it and it doesnt work. i try to convert it afterward with tmpgen it takes 1 second and its done i try to preview it and it shows a picture of da intro. wut did i do wrong. is dere a step i miss?? plz help me out . i almost out of hd space .thx
The clip is too large. Go to lycos and do an ftp search for realproducer plus and cut up the rm. I usually do about 1 minute cuts (depending on where the key frames are). Convert all the cuts to avi and then to mpeg before joining back.
You're using Win 9x/Me, eh? You can't have a single file larger than 2 GB with those repugnant OSs. Install Win2k. In my experience, a 20 minute .rm will convert into a 4 gig .avi.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
