How to convert mpeg1 to mpeg2(dvd)?
I know how to convert avi to dvd. I tried to convert mpeg1 to mpeg2 using Tmpgenc plus the same way I do avi to dvd. It wasdone a matter of seconds but when I check the output files in Avicodec it was still mpeg1.
If you are wanting to put the file on a dvd just upsample the audio to 48k. using a program like besweet or........use tmpgenc dvd author as it upsamples the audio for you. Other than that. Of course thats only if the mpeg1 file is 352x240\288 resolution.
Donadagohvi (Cherokee for "Until we meet again") -
YepOriginally Posted by freebird73717
I'd suggest that you didn't do it properly thenOriginally Posted by paseo
It should take as long as a normal encode - anywhere between runtime and about 4X runtime depending on your rig.
You need to fully re-encode, and make sure that this setting is set:
If in doubt, Google it.
How to convert RM/RMVB to AVI or MPEG1/2
By kschang in forum User guidesReplies: 112Last Post: 11th Feb 2012, 19:56 -
H264 to Mpeg1
By Timex in forum Video ConversionReplies: 5Last Post: 5th Dec 2008, 23:00 -
MPEG1 anyone else?
By peterbuilt in forum Newbie / General discussionsReplies: 30Last Post: 11th Feb 2008, 22:31 -
dvd to mpeg1
By videogirl in forum Video ConversionReplies: 2Last Post: 17th Dec 2007, 19:26 -
Trying to convert WMV to MPEG1 on a slow processor
By Gooey in forum Video ConversionReplies: 2Last Post: 21st May 2007, 03:59
