Hello
OK call me stupid but I can't figure out where I go to find out what version of DIRECT X I have installed.
- John "FulciLives" Coleman
P.S.
I have Windows XP Home SP2 installed.
Results 1 to 10 of 10
Hello,
HAPPY NEW YEAR
Simple:
START - RUN - DXDIAG
ok.
STUPID!
1. On the taskbar at the bottom of your screen, click Start, and then click Run.
2. In the Run dialog box, type dxdiag
3. Click OK. A dialog box displays the version that you are running.
4. Send me money -
Hello,
Umm.....:Originally Posted by offline
I believe I already said that!Originally Posted by yoda313
Yes, but you skipped Step one...Originally Posted by yoda313
Originally Posted by FulciLivesNothing can stop me now, 'cause I don't care anymore. -
Hello,
Ok I'll grant you thatOriginally Posted by Viral1
OK thanks.
I have DirectX 9.0c
I figured that was what I had but I wanted to make sure.
I'm not scared of the RUN / COMMAND PROMPT ... use it for PULLDOWN.EXE thank you BUT ...
Couldn't they just put something in the CONTROL PANAL somewhere?
Seems overly "complicated" not to have it listed somwhere simple.
*** EDIT ***
Happy New Years !!!"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Here ya go... http://www.majorgeeks.com/download4017.html
'This is the Control Panel for Microsoft's DirectX 9.0c with a variety of configuration settings. To install, please copy the directx.cpl into the Windows/system32 folder. Now you have the chance to access the Control Panel from your Settings menu. Alternatively click on the file to launch the panel. It's designed for Windows 98/ME/2000/XP/2003'
EDIT: I installed it. Works like a charm.
I started typing before you Yoda but grabbed a ciggy
while you must have answered the question.
I'm still in recovery mode too. -
Hello,Originally Posted by offline
No harm done.
Just a little friendly jab
HAPPY NEW YEAR
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 10:44 -
xvid4psp 5 crashes after version 6 installed
By craigarta in forum Video ConversionReplies: 0Last Post: 12th Aug 2011, 18:04 -
DirectX
By CSULB71 in forum ComputerReplies: 4Last Post: 12th Jul 2009, 17:13 -
DirectX X for XP?
By Xylob the Destroyer in forum ComputerReplies: 7Last Post: 8th Jan 2008, 18:46 -
Can someone with TMPGEnc installed check here?
By berfles in forum ComputerReplies: 3Last Post: 4th Jul 2007, 16:11
