For some strange reason, I can't get VCDEasy to make me SVCD's that work in any player, or software players like PowerDVD. It's not the burning process, but the image creation. Even when mounted via Daemon Tools, the BIN/CUE image doesn't work! I see all the files, but it doesn't play. Nothing.
Making the same SVCD within Nero's crappy software works fine, although it doesn't allow chapters because Nero is so limited.
My question is: What other good alternative SVCD software is out there for me to try?
Thanks,
Robert
Results 1 to 10 of 10
Nerovision Express 2 has chapter and menu creation...
Cheers, Jim
My DVDLab Guides -
They don't work with Theatertek either. I'd like them too, because software players are my primary target (although I do have a DVD player, which I could try.)
-Robert -
Hey wait a minute! Watch out for what you say with so many newbies reading! I have read many reviews of VCDeasy that rate it pretty highly! What's the scoop? Where's the poop? Is it a hardware compatibility issue? Is it an OS issue? It seems that many people out there have been able to get VCDeasy to work...so what gives? I need a decent freeware program to author VCD's, make titles and menus, insert still photos, remove original sound and dubb in new audio (voice). Several people have mentioned VCDeasy as a good starting point with the addition of a few other programs. What gives?
VCDEasy uses VCDImager as the backend and it works perfectly.
If you can't make a working VCD or SVCD with it, most likely you aren't doing something right. --> i.e., user error.
VCDEasy / VCDImager will not automatically correct for problems in your source media files as much as other programs (e.g., Nero) so your problems may lay there.
Regards.Michael Tam
w: Morsels of Evidence -
Originally Posted by Codecoder
A monkey could use VCDEasy. IT'S EASY!
And the output works great.Want my help? Ask here! (not via PM!)
best alternative to nero
By marlo in forum AudioReplies: 12Last Post: 29th Aug 2010, 13:53 -
Anyone have an alternative to 8mm2avi??
By LSchafroth in forum RestorationReplies: 2Last Post: 10th Mar 2009, 16:39 -
wintv alternative?
By sitlet in forum Capturing and VCRReplies: 0Last Post: 6th Jan 2009, 15:29 -
Surcode or alternative
By prizi in forum EditingReplies: 2Last Post: 8th Dec 2008, 10:23 -
Hardata Alternative.
By miceg in forum Software PlayingReplies: 0Last Post: 4th Nov 2008, 15:05
