  1. I downloaded TMPGEnc with the VFAPI plug-in, but I can't open .d2v files still. I am using Windows 2000, that might be the problem.
  2. is the dvd2avi vfp plugin registered properly?
  3. How do you change it? I didn't change anything.
  4. just run the install.bat the vfapi plugin must be on the same folder and then run it..after that copy the DVD2AVI.vfp to the TMPGEnc...and make sure not to delete or move you vobs untill your movie is on a CDR and heppy with
