When I capture my dv video from my panasonic GS120 in adobe premiere all I get is a green screen. Once the video has been captured I can watch it fine, but I can't see what I am capturing. Any help would be much appreciated as I have payed a lot of money for both camera and software.
Does your DV look normal in your media player? My first guess is that you don't have a DV Codec installed or you need to upgrade your DirectX.
I personally would frameserve from Adobe Premiere Pro to TMPGEnc or CCE as APP doesn't really have the best encoder (When you go to Export and even maintain data rate as DV.)
To learn how to do this, go here: https://www.videohelp.com/premiereavisynth.htm
If you're not that picky about your final product, then just export in Adobe. If you're going to use an AVI codec, please use XviD. I have done _a LOT_ of experimenting over a long period of time and I have come to this nutshell conclusion: XviD gives sharper video at smaller filesizes than DivX. DiVX smoothes too much, losing a lot of detail while increasing filesize. A 1 minute DV clip in DivX was 12.5 MBs at 1500 kbps. In XvID it was about 9.8 MBs. Going to encode 30 minutes of video? You're going to notice a significant difference in filesize.
If you want to PM me or even add me to your MSN/ICQ/AIM/Yahoo/Jabber, PM me also for my address. Cheers. -
Try capturing with WinDV and see if you can see the picture then.
Also, WinDV will capture to separate files for each separate bit of recording you've done on the tape - I left my cam running for 30 mins and it caught every clip perfectly in it's own file.
I use Premiere 6.0 to edit, and capturing in that was continuous - you had to start and stop for each clip. WinDV has saved me soooo much time.
I don't know if Pro does that or not.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Cool... No problem.
But it's a bit weird that Premiere isn't. Just remember this if you have seemingly unrelated problems in the future. There may be a common underlying problem...
Still, I prefer WinDV instead of Premiere for capturing.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Adobe Premiere Pro Not Recognizing Capture Card
By ercdill in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2008, 14:59 -
Premiere..... Green Screen Key Effect....
By _impromptu_ in forum Authoring (DVD)Replies: 2Last Post: 27th Nov 2007, 12:08
