I have a set-top DVD recorder that I use to record TV programmes with. This recorder seems to produce DVD's that play fine in all players, but can't be read by tools such as DVD Shrink and generate a non-compliance warning with Nero.
I've tried using IFOEdit ("Get VTS Sectors" option) to correct the error but this doesn't seem to work.
Is there any way of 'fixing' a non-compliant DVD so that it can be read by tools such as DVD Shrink? Or is there some way to fool the tools into thinking it's a compliant DVD?
i use a liteon dvd recorder and have nothing but grief when i put the dvdrs it produces in my pc. if you copy the video t_s folder from ur dvdr to ur hd however you can play as much as you like with it and produce a new disc. (shrink it, reauthor etc)
I'm able to copy the DVD to my HD using DVD Decrypter, but DVD Shrink still can't open it. Surely whatever incompatibility problem exists on the DVD it will be the same even once it's on the HD?
Is there a tool that makes a non-compliant DVD compliant by removing invalid references etc? I thought this was what the "Get VTS Sectors" option in IFO Edit was meant to do but it didn't seem to work. -
This may sound like a silly question, but did you 'finalize' the disk before using it in the computer?
The DVD Recorder only lets you Finalize +R's, not +RW's which is what I'm using (it says in the manual that these do not need finalizing).
DVD recorder conversion to compliant DVD
By snafubaby in forum Authoring (DVD)Replies: 4Last Post: 27th Dec 2009, 05:57 -
Standalone DVD recorder to youtube
By duckvids in forum Newbie / General discussionsReplies: 6Last Post: 10th Jul 2009, 18:46 -
My standalone DVD Recorder is a
By Baldrick in forum PollsReplies: 31Last Post: 12th Nov 2008, 16:21 -
Problem in DVD Recording in standalone DVD Recorder
By prayami in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Oct 2008, 00:35 -
DVD Recorder Standalone
By ebob in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 12:40
