    Jul 2003
    london uk
    hi guys, i had a load of windows open and a program stopped responding when i wanted to close it so i did ctrl alt del to end task with task manager, but i must have clicked end task too many times because my task manager now looks like this;
    and as you can see the top tabs are missing which is really annoying because now not only can i not view the things within those missing tabs, i cant close it as theres no x box in the top right corner. so i have to right click in the bottom of the task bar and select close.
    soooooo! the question is, how can i get my task manager back to normal? i use it fairly often so i would like to get it sorted.
    oh and HAPPY NEW YEAR TO YOU!
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Reboot
  3. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Double-click in the grey border of that window to bring back the options.
    FB-DIMM are the real cause of global warming
    Jul 2003
    london uk
    exellent tip, that worked for me, thanks for that.
