I want to convert some Divx movies onto DVD to play on a DVD player. What program (or method) should I use that will allow me to do that, along with maintaining the resolution of the video? (most divx movies are wide screen, I want them to STAY in wide screen and not fill the entire screen)
Is it possible?
That will depend upon your movie's resolution.
Standard NTSC Resolutions:
720 x 480 pixels MPEG2 (Called Full-D1)
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
29,97 fps*
Standard PAL Resolutions:
720 x 576 pixels MPEG2 (Called Full-D1)
704 x 576 pixels MPEG2
352 x 576 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 288 pixels MPEG2
352 x 288 pixels MPEG1 (Same as the VCD Standard)
25 fps*
Any other resolution will have to be changed to the above. If you have the resolution, then you can try DIKO or the FilmMachine 2 free Divx/Xvid to DVD programs.
Happy Holidays!
RogThere are many ways to measure success. You just have to find your own yardstick. -
Of course its possible.......what encoder are you going to use?....boggo TMPG (slow but it gets there evvvvveeeeenntttuuuuaaallllyyyy) or something else? Can you press buttons on you pc screen (its amazing how many people cant)?
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
