Results 1 to 21 of 21
    Dec 2004
    Well I have a Zoolander divx avi file just like all the other divx avis I have, and I am using TMPGEnc to encode it to DVD format. Every time I do this it freezes on the exact same frame a few mins (maybe 10 or so) into the movie and records that same frame for the rest of the movie. So I get like 10 mins of good video then about an hour and 20 minutes of that one frame with the audio sounding fine. I tried using the Cucusoft avi converter and that just stops the encode at the same point. The avi plays just fine on my computer... is it corrupted or what? This is my fav. movie I want it on DVD!!!
  2. try loading it up in virtual dub, and navigate to the trouble frame. Then either fix up that frame, or just delete it. Now frame serve it over to tmpgenc.
    Some people are only alive because it may be illegal to kill them
    Dec 2004
    Never used virtual dub, but I'll give it a shot. What's frame serving?
  4. it allows you to make edits on a file in a video editor, and not have to save the changes into a new file before loading into mpeg encoder. Rather you can just make a very small temp file (just a few Kbytes) that you load into tmpgenc .
    search the forums with these keywords
    frameserve from virtualdub to tmpgenc
    its bound to come up with exactly what you need.
    ps. virtualdubmod is an awesome and very powerful, simple program, that is very easy to use.
    Dec 2004
    Ok well I scanned the avi file for errors using virtualdubmod and got 0 errors. Now what?
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I'd still say it's a damaged AVI. There are some tools to (try to) correct damaged AVIs, but my experience with those is mixed, to say the least.
    It could also be a codec problem - make sure you've got the latest version of DivX codec - Are you 100% sure it is DivX? If not, use GSpot to find out!
    /Mats
  7. Member Soopafresh's Avatar
    Jan 2004
    DivFix - that app has helped me out many times.
    Dec 2004
    Actually it's Xvid, I wouldn't think that would make much of a difference. Should I still try divfix or is that for divx files only?
    Dec 2004
    Well, we'll see just how late my codec was. I just d/led from your link so we'll see if that fixes the prob. I'll give an update tomorrow. And btw... mats, what exactly <i forget hmtl (italic)> is <still forget how to do italic> your avatar?
  10. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    what exactly is your avatar?
    Why? It's me of course
    Here's another:
    I added the "sweep" in Photoshop (lens flare filter)
    /Mats
    Dec 2004
    Haha I still don't get it. Kinda looks like C3P0 had sex with robocop.
  12. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    A peek at the image name might give you a clue...
    /Mats
  13. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    ... so buy it on DVD then
    If in doubt, Google it.
  14. Member Soopafresh's Avatar
    Jan 2004
    Yes, DivFix will fix Xvid ...
    Dec 2004
    /Mats
    daft punk? still nothing.
  16. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Daft Punk makes some of my fav music - and has a cool image/gimmic - they always wear these robot helmets, and never show their faces. Silly but cool!
    /Mats
    Dec 2004
    So nobody has ever seen their faces or know what they look like?
  18. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I'm sure someone has - but there are very few pics of the duo without them.
    /Mats
    Dec 2004
    have you seen any?
