Hey there. I have a problem with burning with my pioneer drive. I can burn and everything goes real smoot. It does not appear however to be finializing discs properly. I have used mult types of media, multiple programs to burn and nothing seems to be working. I burn an iso file and when i load the cd, the title screens will come up, but, when i hit install all fails. Cd's burnt with this recorder at the end just stick, they don't advance the final track so the next cd will come on (as in say a changer).
Thanks for any advice
Hey there again, I just had a friend who had a dvd burnt from an iso image on his recorder and it works fine. I try it on my pioneer and when i hit "install" for the program, windows task manager says "not responding". If I wait a bit, before windows auto shuts the program down, it may eventualy seek up on the drive, but for the most part it shuts the program down. It appears as though the drive isn't spinning up to find the required data. Any ideas anyone or is this another best buy returned product?
Thanks in advance.
Problem with video out on Pioneer DV-490V
By Benhermies in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Apr 2010, 16:52 -
Pioneer DVR 533HS Problem
By Hollywood_Mike in forum DVD & Blu-ray RecordersReplies: 25Last Post: 13th Aug 2008, 12:35 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 05:36 -
Problem, with my PIONEER 111d writer
By Gewin in forum DVD & Blu-ray WritersReplies: 7Last Post: 24th Dec 2007, 07:51 -
Pioneer DVR 533 Problem -
By chris_james in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Aug 2007, 02:59
