I am sure this is a simple answer. I just bought a Toshiba SD340E which can play DivX/MPeg4 movies.
I use Nero6 to burn my CDs. Toshiba recommend that I use CD-R and not the CD-RW (not sure why but I will try anyway.)
My question is how do I use Nero 6 to burn the DivX file to CD-R so I can play it on my DVD Player
thanks
For my philips i would guess would be the same.i just burn them as Data and make sure to close the Disc.
If I use Burning ROM shall I select CD-ROM (UDF)or CD-ROM (UDF/ISO) under the "New Compliation" window? or even another?
Also I have noticed that most of my DivX files are over 650M. Is there a way to reduce the size to fit onto 650M CD-RWs? -
Hi-
Yes, but it's more trouble than it's worth, and you'll lose quality. Since 700MB is the standard these days, why don't you buy a stack of them, and save the 650's for when you have smaller files to burn.
Choose CD-ROM(ISO) (up at the top).
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
burning divx files as data to play on dvd player
By penguyen in forum Authoring (DVD)Replies: 4Last Post: 30th Jul 2011, 11:54 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Burning AVI file to DVD-RW to play on a Divx DVD player
By Jay8284 in forum Authoring (DVD)Replies: 4Last Post: 5th Jan 2008, 15:03 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
