  1. I have a nice for all who have DVD/VCD Player that does not support MP3 here is the answer MP2 (Mpeg layer-2)
    It works great on my pioneer DV-525. shure the file will be not so small like Mp3 but youŽll get very much music on cd-r
    Moggi
    Feb 2001
    Berlin, Germany
    http://www.vcdhelp.com/tw_audio_sevcd.zip
    This is a TMPGEnc template that enables 6+ hours of audio on a single XVCD, including a textfile how to use it.
  3. Why does the template make video (picture+sound) i make only system only audio mpeg1 layer-2 VBR
    for example my template
    a mp3 192kbit/s file 3.59min size 5,622,308kB
    the same file with your template 7,394,968kB
    the same file with my template 6,643,716kB
    couse i use Mpeg-1 LayerII
    Sampling frepuence 44100Hz
    bitrate 224 kbit/sec
    Stream type Mpeg-1 system(VBR)
    system (audio only)
    and it works perfect
    Moggi
    Feb 2001
    Berlin, Germany
    no, no, it is not my template. It uses VBR CQ quality=0, that means minimum video bitrate. I guess most dvd players can not play a XVCD without a video file. If your player can handle that, you are lucky. However, nice to know, I will try it. Thank you.
    Feb 2001
    Berlin, Germany
    One more question. Do you burn the .mp2 files as VCD or CD-ROM? And which burning software did you use?
  6. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    hi truman, i burn a VCD with Nero and i use .mpg (system only Audio)extension because nero does not support .mp2 (only audio).
    Moggi
    Feb 2001
    Berlin, Germany
    I did it alreaddy. But no success with your method, my player does not accept it.
