I have some old DVD's that I have had for a long time, and would like to back them up before it's too late. My problem is that they still play fine, but won't copy. I get read errors during the copy. I have tried DVDShrink, CloneDVD2 and DVDmate. What is the best software to try and salvage these old movies? thanks
Hello,
Other rippers:
smartripper
dvd decrypter
and more in the tools section on the left <-------
Good luck.
KevnDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If your dvd's are old and used many times, they
probably have some scratch's on the playing
surface. You can polish them out with white
toothpaste, diluted with a few drops of warm water.
Polish from the hub out toward the edge, NOT in a
circular motion.
Hope this helps you some and a Happy New Year.
kiki
avi.net backing up Iron Man 2 DVD>divx audio problem (SOLVED)
By crazifunguy in forum Newbie / General discussionsReplies: 7Last Post: 31st Oct 2011, 23:11 -
Problem backing up Blu-Ray using BD Rebuilder with milOtis method
By TJMac44 in forum Blu-ray RippingReplies: 15Last Post: 7th Mar 2011, 14:43 -
Problem backing up my copy of transformers 2,i got it ripped but can't burn
By sscottsa in forum DVD RippingReplies: 1Last Post: 22nd Oct 2009, 18:18 -
Problem "backing up" Confessions of a Shopaholic
By jamesprime4328 in forum DVD RippingReplies: 4Last Post: 3rd Sep 2009, 14:15 -
burning problem with backing up my dvd's
By sscottsa315 in forum Authoring (DVD)Replies: 8Last Post: 5th Mar 2009, 20:36
