Hello everybody,
I want to send DVD player to my relatives in Europe. I bought Cyberhome CH-300 DVD player in Walmart and testing it right now. It supports dual voltage 110-230 volts, can play PAL on NTSC TV and vice versa. But this little sucker freezes for a second every 3-5 seconds at the end of each burnt disk, no matter if it's +R or -R.
My question is: what other multysystem DVD players support dual voltage and can play PAL on NTSC TV and vice versa that I can buy in local stores like Meijer, Wallmart, K-Mart, Target, Best Buy, CompUSA etc.?
Thanks.
Are you sure the problem isn't the media you're using? That sounds exactly like how bad media behaves on any player.
this is THE ONLY player that support this.
I have one, plays fine. It's the media, check you disc.
what DVD players support most video formats?
By BassJunkie in forum DVD & Blu-ray PlayersReplies: 11Last Post: 14th Feb 2009, 12:54 -
Does these video cards support dual screens?
By SingSing in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2009, 20:36 -
Players that support multisession rewritable disks?
By rvman in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Mar 2008, 10:30 -
Media players with Purevideo support?
By rhythminmind in forum Newbie / General discussionsReplies: 3Last Post: 12th Oct 2007, 13:58 -
dvd players that support rmvb??
By lilxtwinkies in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Sep 2007, 00:03
