i use vdub to rencode avi to avi for my 642,,but i cant find a resize feature anywhere in xvid,,some full screen movies i'd like to make widesreen,or just reduce a little during reencode for quality,,but its not there like in divx
huh?
vdub has resize filters"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
VirtualDub: Video -> Filters -> Add -> Resize. You must be in Video -> Full Processing mode.
ok,,thanks,,i've never really fooled with the filters and just expected it to be in the configure like divx's is,,,thanks junk
XviD is just a video codec. I know DivX has stuff like that in it, however that is not the job of a codec.
I wouldn't recommend using VDub's filters as it means converting to RGB24.
Need help with DVD resize
By Enkidu in forum Newbie / General discussionsReplies: 15Last Post: 21st Jan 2011, 13:18 -
Resize Divx/Xvid For Portable With VDub: Artifacts/blur
By gordonliu in forum Video ConversionReplies: 6Last Post: 4th Apr 2009, 09:42 -
Resize HD to SD
By ron spencer in forum Authoring (Blu-ray)Replies: 9Last Post: 1st Jan 2009, 13:52 -
.sup resize...
By alcOre in forum SubtitleReplies: 1Last Post: 1st Dec 2008, 04:57 -
Fast simple way to resize Xvid
By Maxwellbest in forum Video ConversionReplies: 8Last Post: 2nd Feb 2008, 18:32
