Just bought a 4kus dvd recorder from asda to replace the liteon 5005 that i took back to argos, both have the same issue with mpeg audio, the audio keeps cutting in and out, usually about halfway through the dvd. These are all homemade disks created with svcd2dvd, I have tested over 30 so far, all on different media and the issue is the same. AC3 audio and PCM is fine, does anyone else have similar issues? I think bad media and bad encoding can be ruled out as i have tested so many different disks. Can this be fixed?
