    Jul 2004
    Canada
    ok so I want to upgrade my system. I have had this same system for 3-4 years now (with the exception of adding a new DVD writer - LG GSA 4120B).
    I honestly dong know how to make any sense of this stuff, I dont speak "MHz" (yeah I know, sounds like its pretty crucial) or really understand what the Front side bus speed/frequency translates to as far as performance goes.
    I DO want to be able to make backups faster (as far as time goes, I'm looking at 5-6 hours each disc with shrink-2 pass.. deep analysis ) - I dont actually know how fast I could get (quotes anyone?) but I would like to shave off at least some time.
    heres my multimedia whore's details:
    CPU(s)
    Number of CPUs 1
    Name Intel Pentium 4
    Code Name Willamette
    Specification Intel(R) Pentium(R) 4 CPU 1700MHz
    Family / Model / Stepping F 0 A
    Extended Family / Model 0 0
    Brand ID 8
    Package mPGA-478
    Core Stepping C1
    Technology 0.18 µ
    Supported Instructions Sets MMX, SSE, SSE2
    CPU Clock Speed 1693.1 MHz
    Clock multiplier x 17.0
    Front Side Bus Frequency 99.6 MHz
    Bus Speed 398.4 MHz
    L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
    L1 Trace Cache 12 Kµops, 8-way set associative
    L2 Cache 256 KBytes, 8-way set associative, 64 Bytes line size
    L2 Speed 1693.1 MHz (Full)
    L2 Location On Chip
    L2 Data Prefetch Logic yes
    L2 Bus Width 256 bits
    Mainboard and chipset
    Motherboard manufacturer MICRO-STAR INTERNATIONAL CO., LTD
    Motherboard model MS-6558,
    BIOS vendor Award Software International, Inc.
    BIOS revision 6.00 PG
    BIOS release date 11/23/2001
    Chipset SiS SiS645 rev. 1
    Southbridge SiS ID8 rev. 0
    Sensor chip Winbond W83697HF
    Graphic Interface AGP
    AGP Status enabled, rev. 2.0
    AGP Data Transfert Rate 4x
    AGP Max Rate 4x
    AGP Side Band Addressing supported, not enabled
    AGP Aperture Size 64 MBytes
    Memory
    DRAM Type DDR-SDRAM
    DRAM Size 256 MBytes
    CAS# Latency 2.5 clocks
    RAS# to CAS# 3 clocks
    RAS# Precharge 3 clocks
    Cycle Time (TRAS) 6 clocks
    Bank Cycle Time (TRC) 10 clocks
    # of memory modules 1
    Module 0 Apacer Technology DDR-SDRAM PC2300 - 256 MBytes
    Software
    Windows version Microsoft Windows XP Workstation Service Pack 2 (Build 2600)
    DirectX version 9.0c
    I'm looking for anyone's (And everyone's) suggestions as to what to improve to gain better performance. I'd like to say money is no object, but so long as its about $200(CAD)/piece, I can do it (try to factor in trade in value if it would help).
    thanks ALOT everyone for helping me out, I REALLY appreciate it.
    scratch the surface off a cynic - you will find a disillusioned idealist.
    Jun 2004
    USA
    It takes me about an hour to backup a DVD movie. I use Shrink and DVD Decrypter.
    My system is a P4 2.53, 512Mb, Dedicated 120Gb HD, 533Mhz Front side bus, HP 200i DVD Writer, XP SP1.
    CPU is the big player in how fast transcoding and or encoding go. There are other factors such as HD speed, how frequently it has been defraged, if it is dedicated, if it is a master or a slave, how stuff is running in the background and so on.
    bits
  3. Member Skith's Avatar
    Bottom of the ocean
    before anything, I would suggest adding more RAM, seeing as you only have 256MB. My next suggestion would be a new CPU. You would have to check MSI's website (Micro-star International - the maker of your motherboard) to see what options you have. The newest CPU models would most likely require a new motherboard (anyone correct me if I am wrong, I am not to familair with INTEL stuff).
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
